Question about Canon Compatible Toner Cartridge Replace E40,E31,E20,E16 Printer
E16 error , driving me insane !!!
Hi there , refilled my canon mp 160 cartridges and am now getting a e16 error , have tried everything just cant seem to get any joy ....
suicide pending ................argghhhhhh
  • 81 Answers
E16 means that the printer does not know the ink levels. I am unaware of a reset for that.
Posted on Jul 30, 2008
How to make Canon pixma MP-220 to recognise refilled ink.
Read the manual.
Get online and got to www.google.com In the google search box type: "Canon Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals on the site.
An Error Message Is Displayed on the LCD (MP220 series)
Message
Action
CHECK INK
U051/U052/U053/U059
The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Printer Cover) and install the appropriate FINE Cartridge.
If the error is not resolved, the FINE Cartridge may be damaged. Contact your Canon Service representative.
Jun 02, 2012 | Office Equipment & Supplies
Tip
Canon mp 240,250,270
error E05,E13,E16 is an error cartridge and you need to replace the cartridge with a new one original canon,not refill.
on Feb 28, 2011 | Office Equipment & Supplies
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16-E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp 530 error u043 cant get rid of it
It is registering a empty ink cartridge. If you had the cartridge refilled instea of replacing the cartridge that is what happened. The chip on the cartridge wont register the refilled ink and tells the printer it is empty.
Oct 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannon MP600 error message U052
Hello all, I have had an MP600 for a few years now, and after paying about £50-£60 a set of inks i decided to use compatible ones and i also spent £20.00 on a ink resetter from Sudhaus http://www.patronenhandel.de/shop/en/Redsetter/MP-Serie/MP-600/mit-Refill-Set
After about a year of owning the MP600 i got the dreaded U052 error, so i went back to genuine inks, however this did not clear the error. i then decided to telephone Canon and they advised me to clean the print head thoroughly. If you look at the print head there is a white plate with 2 screws either side, i rmoved that CAREFULLY and cleaned behind it, i reinstalled everything back to normal and 2 years later i am still running perfect with no issues what so ever...I'm not sure what resolved the issue but i now refill my genuine cartridges myself and reset the chip with the Sudhaus resetter. To refill your cartridge use the tube inside the genuine ink cartridge DO NOT refill from the top, you will see the 2 arrows on the GENUINE ink cartridge pierce between there and use a long syringe to refill.
Hope this helps people in the future.
Jan 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Hi, my canon pixma mp210 shows error 61 or 16 after refilling black ink... ? thanks!
Dear cappina,
Error code E16 indicates that remaining ink is unknown. It is common problem in refilling the cartridge. To fix this problem you need to deactivate ink level detection function. Follow this procedure: press and hold STOP/RESET button for about 9 seconds or more then release it. Now E16 has disappeared and the printer should work properly. As consequence, ink volume in panel become UNKNOWN. No problem. It will be back to normal condition when you replace the cartridge with new one.
Regards,
Source:
Canon Inkjet Forum
Dec 11, 2008 | Office Equipment & Supplies
I am trying to reset the empty ink cartridge error code on a Canon mp-530 multifunction printer after installing a refilled a refilled black ing cartridge
Hi, did you refill yourself or did you buy a refilled cartridge. If you purchased a refilled cartridge and the chip is missing, you will need to take the chip off your old cartridge and install on the refilled cartridge.
Jun 21, 2008 | Canon Office Equipment & Supplies
Mp 145
How to reset the e27 for canon mp145 printer?
May 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Mp 160 don't work
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Jan 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
1,116 people viewed this question
old marine
old marine
