Question about Motorola Mobility RAZR V3c Cellular Phone
Bluetooth light is on and it is draining my battery
I don't even use bluetooth, I don't know why the light is on. It's lit up on the front of my phone. Please help
    Sergeant:
  • 359 Answers
Go into the settings of the phone and disable. if that doesn't work get a new phone.
Posted on Aug 12, 2008
I want to use my motorola H680 bluetooth on my new phone and it ask for a numerical pass key but I don't know it?
It is hardcoded to '0000' (four zeros). Well, when you turn it on for the first time, its indicator light should be steadily lit in blue, thus indicating it is in pairing mode. If it has been paired to another device before, make sure that that device's bluetooth radio is turned off. If the light is not steadily lit, turn your headset off, wait for some 10 seconds, and turn it on again. Anyway, whilst its light is steadily lit, make you phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, it should enter the stand-by mode (indicator light starts flashing in blue). You see, the pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections between them should be achieved just by bringing they within each other's range, with their bluetooth radios turned on. At most, a simple press on the headset's call button should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards, Carlos
Jun 20, 2011 | Motorola Mobility H680 - Headset -...
Tip
Making Functional Bluetooth on Acer TravelMate 2420
<p>Laptops are ideal for business and personal use by its compact size and capabilities. Bluetooth technology in combination with a notebook PC extends its use and effectiveness. The Acer TravelMate 2420 comes equipped with Bluetooth and can be functional in a few steps. <br /> <p><br /> <p>1. Download Bluetooth driver in the Resources section. <br /> <p><br /> <p>2. Follow the instructions to install the driver for your Acer TravelMate 2420. <br /> <p><br /> <p>3. Press the "Bluetooth Communication" button on the front of the computer. The button is located on the left side of the "Wireless Communication" button. The light will remain lit to indicate that Bluetooth is ready to run on your computer. There will also be a Bluetooth icon visible on your screen. <br /> <p><br /> <p>4. Prepare your paired Bluetooth device. Acer TravelMate 2420 is ready to connect to your Bluetooth device. <br />
on Jun 26, 2011 | Acer TravelMate 2300 Notebook
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
Skywing bluetooth
PUT H700 HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Then on your phone, search for new bluetooth devices and connect. the defaault code for the HS is 0000
Jul 01, 2008 | Motorola Mobility H700 Wireless Headset
I know NOTHING!
The LG HBM 730 has a muti-function key on the front of the bluetooth. You can recognize it my the semi-circle (phone) symbol. When Bluetooth is on it is 'red'. It is actually a button (not obvious though). Hold it in for 8 seconds or so to turn it on. The light is a give-away when it's on.
Pairing is just the term used to indicate your phone recognizes your bluetooth. You need to set up your phone to recognize the bluetooth that you have.
May 28, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Bluetooth Icon not working
I had the same problem with my nokia n80.
The solution i found is:
with the remote go to bluetooth phone. then on the remoete av menu. now you can select bluetooth as it's not grey anymore. i would advise search device with a new pin and not the standard 0000.
Good luck.
Let me know if it worked. It did for me. (eu model)
Sep 23, 2007 | JVC KD-AVX33 Car Video Player
Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
May 26, 2007 | Jabra BT250 Consumer Headset
Motorola Mobility RAZR V3c Cellular Phone Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
