Lexmark Ptrinter730 series has stopped working the computer keeps telling me that there is a problem which I know alresdy The blue Power light is on and flashing I have checked
Double checked all the connections involved and something I did seem to have worked
Posted on Jul 31, 2008
Wont turn on
did you check the usb cable try another cable if not check the power cord if it dose not turn on then you need a new one
Oct 29, 2013 | Lexmark X7350 All-In-One Printer
I have a x6650 series printer and I am trying to scan a document but it keeps telling me that it can't retrieve my application list. However it has already scanned something for me today and...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect it from your computer. Reboot your computer. Unplug and re-plug your printer from the power source to reset it. When the printer turns on, reconnect it your computer. Try to scan again.
If the printer is wirelessly connected to the computer, check the status of the WiFi light. Green light means your printer is connected to your network. Orange means otherwise.
Jun 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
I have an (all in one 6200 series,keep getting error message/lexmark web gateway has stopped working/ezprint.exe has stopped working
There is no answer to this yet from a Google search. I have asked Lexmark for a solution, presumably a software update.
Jul 08, 2009 | Lexmark Office Equipment & Supplies
Setup.exe stopped working on all-in-one lexmark x5470
it is not a problem your printer your printer driver is not supported vista driver previous driver is supported only xp service pac 2
you update your driver online or www.lexmark software
Jul 05, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Lexmark X4530 left cartridge incorrect
You must upgrade your firmware on your printer.
Lexmark has a technical support bulletin :
Cartridge Numbers 23 and 24 Are Not Recognized on X3500-4500 Series Printers
Jun 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Mar 07, 2009 | Lexmark X3350 All-In-One InkJet Printer
Lexmark c760 printer stopped printing, no lights no power HELP
if you have no lights on the display, the possibility of a bad power supply is good, bring it to any of the computer store with a service or a computer repair shop, have them check it. if you have voltmeter, test the output from the low voltage transformer that goes into the printer against the rating on the transformer.
Mar 02, 2009 | Lexmark C760 Laser Printer
Lexmark 2500 Series printer does not work properly.
my printer does not print, but tells me i have prints pending
Sep 13, 2008 | Lexmark X2500 All-In-One Printer
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
