Minisplit flashing code - water dropping
Hi - my Toyo minisplit will flash error code - 4x in 8 seconds. At this time the fan will slow down and the unit will sometimes drop water from where air exits. After a few minutes - the unit will return to normal, only to start this again in 10? minutes. Seems to cool well.
Any ideas?
Thank you
  • 236 Answers
Check your air filter and indoor coil fins if clean. If it is dirty it need to be clean. But if it is clean you need a qualified technician for this problem.
Posted on Aug 05, 2008
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Codigo de programacion taika modelo tkb-ac
Tengo un control remoto marca taika TKB-AC y Busco el codigo de programacion para un minisplit marca LG
Traductor: I have a remote control taika brand TKB-AC and the programming code looking for minisplit brand LG
Nov 10, 2013 | Televison & Video
Frigidaire FRS12PYS1 E-6 error code
I have a united minisplit fridigiar 12. 110 volts
E6 drive failure. to that is the error.
Apr 03, 2012 | Frigidaire FRS12PYS1 Split System Air...
I need help on how to activate heating mode in my 7wa4501q whirlpool 6th sense minisplit pleasee
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 13, 2011 | Heating & Cooling
I have a minisplit unit that leaks out the freon
try leak stop that they sell for refrigeration and air conditioning systems
Dec 12, 2009 | Heating & Cooling
I need a fan motor for my ge minisplit as0cd12db0 outdoor unit. Where can I get one?
Appliance Parts Pros 1-877-477-7278 or website appliancepartspros,com, Part# AP2053915 fan motor made by G.E. $119.82
Oct 17, 2009 | GE Quiet-Aire Ductless Mini Split System...
My mini split does not run
Check that you are on the correct mode setting. Open the remote and press the mode button (the one with about four little icons, star, teardrop, triangle and sun) until you get to the mode you require. If cooling required, select the star or crystal, if heating required select the sun (circle with little lines)
Mar 06, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Lg minisplit heat pump will not heat
You may want to check that the pressure switch is not functioning? Secondly there is also a thermo sensor on the condenser coil which could be faulty.
Feb 26, 2009 | Heating & Cooling
Heating & Cooling Logo
274 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
