C-Technologies C-Pen 600 Handheld Scanner
Problem for C-Technologies C-Pen 600 Handheld Scanner
C-pen 600 malfunction
By vclatino1 on Jul 30, 2008
I have used my CPen 600 for the last 3 years, but no longer turns on. I've recharged my AAA batteries, but this does not work either. I believe there might be something wrong with the pen itself. If you are able to provide assistance, please contact me via e-mail at gil@umail.ucsb.edu As I am in the middle of completing my dissertation, your assistance will be greatly appreciated. I look forward in receiving your response.
Best,
Oscar
Comments:
Jul 30, 2008
- The battery(ies) are the not the problem. I placed the batteries in another item and they work just fine. I always carry two sets to use with the Cpen, which means all four batteries work just fine. Please provide an alternative solution.
Thanks,
Oscar
Jul 30, 2008
- How can I determine if it is either the battery contact or another internal problem on the hardware? I have successfully opened the device, but where do I go from here?
Best,
Oscar
Solution #1
posted on Jul 30, 2008
Somewhat Helpful)
marked
Rank: Guru  Computer Hardware  Expert
Rating: 86%, 969 votes
How about if you change the battery? because that can also be a problem with the battery or some of parts inside it..
Hope that helps......
Comments:
Jul 30, 2008
- Ok this can be a problem with the unit itself , probably the board is damage...
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
battlesmith
Rank: Wiz
Rating: 82%, 126 votes
Well As you suggest That the Batteries are Quite fine and charged,We can assume that either the device is down due to an internal problem in the board or the Cord which is in contact the battery is not working..Thus in Both the cases i would highly advice you to take th C-pen for service to the authorised Company Service centre Who can service it unless Hopefully it is not the time To Replace it in case Where you must a new one my friend..
Thank you!!...
Regards!!..
Comments:
Jul 30, 2008
- Well if you can read the circuit well check for the connections and check if theres any break in it..If so Try to fix it or else please Check With the terminals that connect to the batter contact..It should lead you to the solution!...
Jul 30, 2008
- But i would kindly advise you to take it to any Professional Serviceman For servicing as it a Sensitive Device where any minor fault would complicate the problem my friend!!..Thank you...
Was this helpful?
Yes
No
Solution #3
Not Rated)
DARKLORD1
Rank: Guru
Rating: 86%, 725 votes
No power is one of 3 things
1.) Battery / Contacts
2.) power switch or button
3.) dead mainboard.
If its oisnt the battery or the battery contacts then more than likely its the main board thats damaged. You may eighter contact the manugfacturer for a replacement boad or you may need to buy a new one. Other than that there isnt much you can do. As to repairs itself on the board, Its microcircuits which makes repairs and modifications by human hands really difficult.
Was this helpful?
Yes
No
Solution #4
Not Rated)
maklean
Rank: Guru
Rating: 86%, 651 votes
Was this helpful?
Yes
No
Solution #5
Not Rated)
voodoomox
Rank: Wiz
Rating: 83%, 417 votes
if you are able to open up the unit, please try to check the contacts of your battery, there is a possibility that the battery contact is broken or rusted.
if it is loose, resolder it and if it is rusted outl just give it a quick cleaning, do be careful though.
good luck
Comments:
Jul 30, 2008
- try to carefully open the unit and check if there are loose solder or broken conenctions, you may need to use a magnifying glass, i would because i have a poor eyesight.
Was this helpful?
Yes
No
Popular Solutions for C-Technologies C-Pen 600
Questions and Unsolved Problems for C-Technologies C-Pen 600
Do you recommend C-Technologies C-Pen 600 Handheld Scanner?
Answer
Answer
My computer will not recognize the pandidgital scanner usb via a 4-port usb hub. Hence can not load... (More)
Answer
Cherche a télécharger driver Acer scan 620S pour WindowsXP pro
Answer
dont know how to program the scanner
Answer
I bought the c pen 600 a few years ago as a present for my dad, unfortunately he never really used... (More)
Answer
I purchased a used C-Pen 600C scanner pen that picks up text quite accurately but I can't seem to... (More)
Describe your Scanners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Scanner Experts
Top Printer Repairmen
in Newport, KY
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
