SOURCE: eflite 60amp esc - no throttle responce
Lower throttle trim all the way. It will arm like a charm.
Cliff
SOURCE: My eflite 40 pro switch esc does not operate the
IF the Motor works fine under a "Dry" test, then really the ONLY place a "Fault" can be is with the controller/switch, these type of units. due to the current they control can Fault very quickly and for no apparent reason.
The controller basically works by passing controlled current to the Motor, if NO current is entering the Motor, yet current IS entering the Controller, then it MUST therefore be the actual controller....
Usually it is the "Output" semiconductors that fail, but occasionally it can be the Micro in charge...
There is no "Repair" as such with these types of controllers, mainly due to the fact that with, "Mission Critical" devices, even a professionally repaired unit, has a higher likelihood of failing again in the very near future, so replacement is the usual way to go... As due to the stresses involved whenever a device like this fails, the co-lateral damage done, and stress on "Other" components makes long term successful results unlikely.
