RCA color Model X13101G5 ChassisTX825XB loss of vedio and sound fuse not opened, set will play for hours not go on next time in use and then go dead again
DID YOU EVER SOLVE THIS PROBLEM?
Posted on Feb 16, 2010
46LA45R RCA 46" TV does not power up following a power loss
If a power loss someone needs to open set and see if when power came back it popped the line fuse, follow power cord inside to the fuse which it goes directly to.
Dec 11, 2012 | RCA 46 46LA45RQ LCD TV
Dead
Check this site for some useful info: http://wa6ati.com/CTC195-197.html
Feb 15, 2008 | Televison & Video
The convergence on this television has obviously developed a problem. The three colors have completely separated. A picture is still visible. I attempted to apply the convergence option from the set-up...
This RCA tv model use a convergence fuse.The covergence fuse FL231 is dead.U have soldering iron,u can do basic soldering?Try Ebay.com to buy the convergence fuse for the replacement.This FL321 have three fuses,the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
Aug 20, 2010 | RCA R52WM24 52" HDTV Projection Television
Blue, red and green lines running across the top of the screen. Picture looks like 3d. No convergence on the menu.
This is self protection on the set. Near the high voltage transformer inside the set (it is located as you look from the back on the far left and will either be black or tan--it has a large red wire coming out of the top of it) next to it are 3 tan colored coils--they look like resistors--one of them is gone----this is why convergence does not show in the menu.
One of two things wrong here---either the part just failed or THERE IS A SHORT IN THE CONVERGENCE circuit--it is spread across the circuit boards---these sets are prone to this and you will find many shops do not want to work on them.
Boards are no longer available from RCA except on a rebuild basis.
All parts are RCA only---the coils may be found at a number of sites but that board has to come out.
The coils can be tested like a fuse (which is what they are).
I have seen other techs in the shop I work for spend hours trying to get one of these sets up again.
If this told you something you did not know, rate my solution here as very helpful as I do this here for free.
lF any questions make a comment here.
REGARDS, SD TECH
Aug 18, 2010 | RCA R52WM24 52" HDTV Projection Television
Colors are overlapping
Is it bowed top and bottow? One fix and a common problem with this set is there is a fuse right next to the flyback the seems to open because of broken solder joints. There is 3 off them and the middle one seems to blow all the time. Check the fuse with a meter and see if its open. If it is, follow the next set of directions.
To fix this, you will need to resolder the flyback and several other components. Then jump the fuse or replace it. I have personally done both but I don't like to jump the fuse because it defeats its purpose as a fuse.
You will need a T-20 and a T-10 screw driver to take the back off. The flyback with be on the left hand side of the set with a red wire coming off the top of it and the fuses will be located an inch or so to the right of the flyback. If you have schematics, sorry I don't know the designations of the components. Another problem, I have seen is on the right hand side of the set. There is a ribbon cable about 2 inches wide. The topside board(Convergence board). That connector is also known to go bad as well. Replace the connector.
Dec 15, 2009 | RCA D52W136D 52 in. TV/DVD Combo
RCA HDR52W87 picture is bent and color is fuzzy; what could be the problem
Dec 02, 2009 | RCA HD52W59 HDTV Projection Television
3 color lines at top of screen no picture
If you do not see convergence in menu when you go to setup then you have a open fuse FL231 Next to flyback transfomer on right side there is 3 in a roll small brown rectanigler looking caps they are fuses the one in the middle is bad replace it .
Feb 11, 2009 | RCA R52WM24 52" HDTV Projection Television
T.V. went off during thunder strom- now nothing(no audio/vedio only clicking.
IN WICH STATE ARE YOU? IF YOU ARE IN MD-DC-VA WE CAN GO THERE AND TRY TO FIX IT
CAYPIANAN@YAHOO.COM
Oct 22, 2008 | RCA Scenium M50WH187 50" HDTV
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
No sound or picture
jerel,
Please provide accurate info for best solution = on back of set =
Model # , service # , chassis # , Mo / Yr built............
Stopped playing = Dead ? ....no sound , no picture, no green
power led on front??...........................Help ! Let me know..T.
Nov 25, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
