Question about Miele Dishwashers
Intake drain light flashing - Miele Dishwashers
  • 2 more comments
  • Anonymous Aug 08, 2008
    Flashing intake drain light
  • doing dishes Feb 12, 2009
    My dishwasher will start itsa cycle and then shut off. Afetr several minutes the intake drain light flashes. I have cleaned the drian and the intake filters but still it won't go thru the cycle
  • Chuckie12345 Feb 26, 2009
    I have same problem - open the door and there is water at the bottom of the dishwasher - when I restart program, the water drains out fine. Also, I have great water pressure coming into the dishwasher, filters are clean, etc. I am suspecting it is a circulation pump problem.
  • Anonymous Mar 29, 2009
    intake /drain light is flashing,full water
1. Unscrew air gap which is on the counter-top next to sink.
2. Unscrew drain clamp under the sink which s connected to the air gap.
3. Use a wire hanger to push down debris clogging the drain.
4. Screw clamp and air gap back in place.
5. The dishwasher should work. Routinely clean out air gap every half year.
Posted on Jan 19, 2009
  • Thierry Jul 25, 2011
    Where is that " air gap?
    Is it below the top cover of the dishwasher or next to the tab?
    Thanks
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Intake/drain light on and cycle stops (Miele G851 SC Plus Actions: Clean out the filter at bottom of machine, then disconect the drain hose at the sink drain pipe. Clean out any visible debris. Further if you wish, use a coat hanger, make a small circle on the end using needle nose pliers, and push this gently up the drain line from under the sink end of the hose. Be careful and gentle. If any debris comes out...You've found the problem . Reconnect everything. Now also under the drain plug under the sink piping and drain it also in a bucket. Turn water on and drain further water in to the bucket. Reconnect everything, put drain plug back in and run a new dishwasher cycle. Things should be back to normal. IF YOU DID NOTICE ANY DEBRIS THRU THESE ACTIONS, THAT WAS THE PROBLEM.
Posted on May 01, 2011
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Apr 18, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
My intake/drain light is on. I have run my garberator. What else should I do to try and fix the problem?
A flashing "Intake/Drain," means something is wrong. It doesn't necessarly mean, "no water coming in," or "poor drainage." But of course, we should check those things first. What are the symptons? What part of the program does the "Intake/Drain" flash?
Oct 28, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Drain is clogged
I had a flashing red Intake/Drain light. After calling Miele tech support, he confirmed that the drain was plugged so I took all drain hoses apart and finally discovered that the problem was a plugged air gap. I replaced it and the problem was solved.
Nov 18, 2009 | Miele Dishwashers
Intake/drain light flashes, and the diswasher won't start.
wash dishes by hand and use dishwasher for storage. lol
Oct 04, 2009 | Dishwashers
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Intake Drain Light
My Miele Incognito dishwasher kept getting an error with intake/drain light. The light flashed 5 times. Phoned Miele Technical Support to investigate the problem. The problem is that a seal in the bottom of the dishwasher has failed and there was water in the motor pan. Currently, $175 service charge for the technician to come look at it.
I don't want to spend $175+ to have them replace a 75 cent rubber gasket that I could replace on my own.
Feb 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Dishwashers Logo
2,287 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
