Question about Maytag Kitchen Ranges
When using the oven or especialy the broiler the outside of the stove (the part where the control panel is), right above the burner gets extremey hot so hot if you would touch it you would get a severe burn and there is a lot of heat that comes out of the stove when oven is used I have not used the oven cleaning option and would not because of the extreme heat that comes out of the stove. Is this normal the dealer we got the stove from says it is and if we have a service person come out he will tell us the same thing and charge us $70.00. I have been cooking for almost 40 years and never have I had a stove with this condition.
  • 254 Answers
There is a vent pipe for the oven in the back usually just under the left rear burner, it is normal too get hot air there, if your drip pans are all solid you might want too change too pans that have holes in the center it should allow the top too breath a little better.
Posted on Jul 30, 2008
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts -
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
What is wrong with our GE Profile Gas Range? After using the broiler and two burners simultaneously, the electronic controls go black. We can manually light stovetop burners but oven does not work.
On the back of the stove are 2 blower fans just under the cooktop. They are cooling fans to keep the controls from overheating. They are a long tube type fan and are left and right side. My guess is one or both are not coming on. They are controlled by a round disk temp control also under the cooktop. At a preset temp these fans should come on and keep all the control area cool enough to stop any damage. The fans need tested and maybe the temp control needs replaced.
Mar 23, 2015 | GE Profile 30" Slide-In Gas Range -...
Kenmore elite stove model #7909912949B. Can get anything to work on oven. Light comes one. Nothing else in the enter panel. Top burners work.
Can you enter the oven temp and press start on the control panel? Do you hear it click on, but it just does not get hot? Try turning on the broiler and see if the broiler gets hot.
Feb 01, 2015 | Kenmore Kitchen Ranges
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
Dec 26, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
Oven and Broiler coils do not heat. Control works okay. The burners heat okay. Set oven to 325 degrees. Drops to 100 degrees. There is a click. and nothing happens beyond that. Try broiler. Set to HI. Does...
There is a relay in the back panel of the stove, this is probably the problem, there is also a temp thermostat in the back leading to the inside oven this cold be bad
Nov 26, 2009 | Washing Machines
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Electric range
the burner needs to be replaced, and as far as the oven goes, if you get the same code when you try to use the broiler setting you may need a new control panel. there should be an envelope on the back of the stove with papers in it, that is a tech guide, it should tell you what that code means. depending on the overall condition of the stove it may be better to replace it then fix it.
Aug 09, 2008 | Kitchen Ranges
Kitchen Ranges Logo
180 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
