Question about Sub-Zero Refrigerators
Sub-zero model#3211-rfd, side by side, freezer working fine, but refrigerator not cold enough, alwaus stays 40F, even i turn to the max.
Have you cleaned the coil? Pop the grate off the top of the fridge and vacuum the coil as well as the grate thoroughly.
J
Posted on Sep 16, 2008
Turning off a sub zero 3211 rfd
replace the thermastat. the switch in the question I mean the contacts inside are stuck or fused closed and are not disconnecting when the set point is reached.
Jan 01, 2013 | Refrigerators
Does the sub zero model 361 rfd refrigerator have a separate thermostat control for the freezer ?
No, the 361RFD does not have a separate control for the freezer as this unit has a single compressor. The control is located behind the back panel in the refrigerator compartment and the part number is 4201470.
Jul 21, 2012 | Sub-Zero Refrigerators
My side by side G E Sub-Zero is not getting or staying cold on the refigerator side, the freezer is working, what could be the problem?
check to make sure the damper door between the freezer and refrigerator is operating and not iced up so it can open fully to let cold air in from the freezer compartment
Dec 25, 2009 | Sub-Zero 632 / S
My sub zero model 3211 has frozen ice at the back of the refrigerator. It's cold but doesn't seem cold enough and some food has spoiled before its time. What could be the problem?
if it is a solid ball of ice, that is just growing out of the back wall, then you need a new evaporator. That is leaking gas freezing the wall.
Jun 15, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Refrigerators Logo
1,498 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
