Question about Sony NW-A1000 MP3 Player
Battery Problems? Low battery please charge warning. Connect charger, sometimes red light on for a few seconds somes nothing. sometimes battery charging icon shows but only for a few seconds. Same problem whether I use the leave and charger or the lead on a USB port. Any suggestions?
Hi all. If you have had your players for some time, and have re-charged them many times over that period (a usual action) then your battery might be near dead.
Most re-chargeable batteries, the longer they are used and re-charged, actually decrease in charged capacity over time.
The only solution, if this *is* the problem, is to fit a new battery. Firms make replacement nw-a3000 etc. batteries for this purpose. I did a google search and found this site:
There are, I am sure, many more sites which can supply you with what you need!
Posted on Nov 03, 2008
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
My battery died and i lost my charger so i bought a universal charger and it says the battery is fully charged, but when i put it in my camera wont turn on at all, a little red light flashes when i hit the...
dear sir,
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours with the original charger,because the charging volt varies from battery to battery of the same brand and using this universal charger is definitely going to harm ur camera very worse,kindly go for the original charger and charge the battery and then put your camera on........
if still the problem is the same ,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest olympus service centre and it is going to be done free of cost,as your camera is under warranty .......
thank you...take care
thank you.....take care................
Oct 08, 2010 | Olympus Camedia C-350 Digital Camera
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
My htc wont open and when i connect charger, led light goes red what happen?
Maybe your battery is dead and will not charge. Normally when you connect the charger the led must become orange after a few seconds and green when the battery is fully charged. If it stays red the battery is not charging.
Jan 24, 2010 | HTC Touch Dual Slider Smartphone
Olympus battery charger flashes red when battery is inserted.
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
Red light blinking on right side on top and white screen and sometimes there is annoying sound
if the battery is very flat, the red light blinks.
try sliding the little battery switch off for a few seconds, then on again, and have the charger connected
Aug 22, 2008 | Navman PiN 570 GPS Receiver
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Battery charger
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Sep 26, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Sony NW-A1000 MP3 Player Logo
80 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
