Question about GE JBP71 Electric Kitchen Range
Oven not working
When I went to start the oven it started clicking and the clock would go off and on. The clock buttons and timer buttons did nothing. The broiler element worked but the baking element never warmed, would a bad element cause this to happen or could something else be wrong? Oven does not work at all, light is not on, timer doesn't work; however, burners work fine.
  • BJTanton Dec 06, 2008
    Oven element only heats slightly.  Clicking sound.  Replaced element with no effect.  Eaton Viking Electric. help.
  • 10,594 Answers
Check its fuses, might be one of them has blown/ open.
Posted on Jul 30, 2008
  • Shahid Electronics
    Shahid Electronics Aug 03, 2008
    • You got any result, any blown fuse?
How do I set the clock/timer to make the oven work?
does it have a clock button , if so press it then use the +or- buttons to set the time then press clock again
Dec 06, 2015 | Ovens
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Electric oven wont heat up
Check your manual to make sure that you can re-calibrate the thermostat as long as your clock is working., the timer works, and the START button is working. If the timer can't be started, it may b3e a touchpad problem. Do you have F1 error message? If nothing is working then there might be a tripped circuit breaker.
Jul 23, 2011 | Whirlpool GBS307PD Electric Single Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Oven not working
Sounds like the oven control which is the clock is bad. The relay for the bake element has probably gone bad and will need to replace the control. You should check continuity on the bake element. If it shows resistance then it is ok. Also, on some models the overlay for the oven control is a separate part. If it is you will need to buy it also.
Oct 09, 2007 | GE JBP71 Electric Kitchen Range
Open Questions:
GE JBP71 Electric Kitchen Range Logo
260 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
