Question about Garmin StreetPilot C330 GPS Receiver
Won't come on
Just quit, will not come on even with power pluged in
I removed the bezel off front, saw the "reset" position and pressed it. It came on for a second. Pressed and help down for a second and this time came up long enough to tell it was working. I now have it charging on my computer - thanks for the tips! would not have know the bezel would come off or that there was a reset function under it.
Posted on Aug 02, 2008
I had this same problem for a few weeks, contacted Garmin and was surprised at how simple the solution was!
On your car charger, unscrew the part that goes into the lighter- counter clockwise--be careful because there are peices stacked on top of eachother. Once opened, you should find a long glass fuse. Just replace that fuse, and it works like a beauty! (I bought a 5 pack for like 3 dollars at auto zone).
Before this I had done all sorts of resets & all, and this actually fixed my problem!
Posted on Jul 31, 2008
After relaceing my motherboard dell d630 won`t power up
Double check your pluge and sockets plus if the motherboard is not the original type, check the processor and chipset match.
Nov 24, 2013 | Dell Latitude D630 Laptop Computer PC...
Simrad Shipmate CP32 Chartplotter won't turn on - any suggestions
bad key pad rick or power on and off switch
Jun 11, 2013 | Boating
Cooling fans won,t come on
1 fan is for cooling the motor and the other fan comes on when the ac is turned on or its very warm outside it 2 stage
Nov 08, 2017 | Cars & Trucks
Tv won't power up when pluged in
Replace the power supply you can get one from www.tvcircuitboards.com
Mar 05, 2012 | Proscan 32LA30Q Television
Ask questions
make sure that the crankshaft position sensor is pluged in(and to the rite connector)you can find it starting at the drivers side upper bell housing of the transmission,then chase it to where it is supposed to be pluged in.
Jan 03, 2012 | Jeep Grand Cherokee Cars & Trucks
I have the oakley bluetooth pro but it won't power up. how can I get this repaired?
I can normally repair them as long as they have no water damage. When the charger is pluged in does the led come on? With a dead battery or one not even installed the led should come on. If it does not then its probably the logic board and Oakley do not sell spares.
Aug 11, 2011 | Oakley O Rokr Pro Sunglasses
My iPod touch won't trim on all it did was light
remove battery and press the power button for 10sec and re insert the battery and try...
Jun 27, 2011 | Apple Audio Players & Recorders
Tomtom won't turn on or off. So I can different screens
does the socket in your car stay powered on even when the car is turned off most likely not and you just need to charge your device will itcome on when it is in the cradle for the computer
Dec 27, 2008 | Tomtom ONE GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
37 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
