Question about GE 30 in. Profile JGP933SEFSS Gas Cooktop
How to Replace only base of my GE Gastop?
Where to find and how to replace my GE Gastop base, my tenents moved out and now I saw that base of my gastop is dirty, everything else works fine.
  • 59 Answers
Hello
The place that I get all my parts is:
http://www.vvapplianceparts.com/
I hope that helps.
Call them and ask them, they will help you and send you the parts you need.
Eddie Rentas
Tupper Lake NY
Posted on Jul 31, 2008
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
Regarding: GE Monogram Cooktop ZGU48N4G The problem I have is that I need to remove the brass tubes that attaches from the burner base to the inside. The brass tube (Chamfer) bound up and broke someth
I have a ZGU375ZSD. Same issue. I could not get below. I drilled a whole in the side, and used a hack saw and tin snips to cut a much larger hole so I could get vice grips on the lower nut. I bent the metal back and put some metallic tape over the whole. I figure the unit is under the counter, and in my case on the back side. GE said it was not repairable, offered me a 75% discount on a replacement. I fixed for around $400 instead of $1,200 replacement. There really is not good solution.
Dec 13, 2012 | Thermador PC366BS Stainless Steel Gas...
One of the ignitor is cracked. Do I need to replace the whole burner base?
you do not need to replace the whole burner base you need to replace de ignitor
Sep 24, 2011 | Jenn-Air JGC8536 Gas Cooktop
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
GE Cooktop drop-in model # jgp328bec2bb - how to take apart the cooktop,I need to replace the spark ignitor switch harness.
Turn off the gas,unplug the power.
Take the cooktop out of the cutout and support it on the countertop.
Remove all grates and valve knobs.
Remove all screws from the valves and the burners.
Remove the burner base plates.
You may have screw on the side holding the top to the base,if so,remove these too.
The top will separate from the bottom exposing your parts.
Feb 11, 2010 | GE 30 in. JGP328 Gas Cooktop
Hi- are you really there?
YES people are really here. Can't answer every question. Try to answer as many as we can. It always helps to list your brand and model number, what's wrong or what you have tried, etc.
Feb 05, 2010 | GE Profile JGP636 Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
The high flame doesn't seem to be working on any burners
hi gud day...try to remove the nozzle inside the burner base using open wrench(depend the size)the use vacium,put the vacium were the place of the nozzle,i think there some dirt inside..then return it again the nozzle to check if it works,,if not replace the regulator for the 2nd sollution.
tnx gerbee
Sep 11, 2009 | GE Profile JGP636 Gas Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
GE 30 in. Profile JGP933SEFSS Gas Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
