Question about Samsung HLN567W 56" Rear Projection HDTV
Replacing DMD board on samsung dlp tc - Samsung HLN567W 56" Rear Projection HDTV
  • dtileguy Dec 10, 2008
    dmd board is bad looks like a negative image. gets worst over time. cant find the boards anywhere.
  • parrot16 May 11, 2010
    what does a dmd board look like and what does it do?????
You need the dlp chip part Number 4719-001981 you can order at www.partstore.com
Posted on Jan 21, 2009
2 Suggested Answers
SOURCE: DMD Board failure on Samsung DLP
Try here:
http://www.partstore.com/GetModel.aspx?MfgName=Samsung&BrandName=Samsung&ModelNumber=HLN5065WX&PartCategoryName=&Keywords=board&Page=1&SortBy=price&SortDirection=asc#PartsearchSKUList
Posted on Feb 02, 2009
Samsung DLP DMB Board BP94-00478A
Not real easy and not a cheap part---have to remove and when replace move and center picture on the screen with the set on--considering replacement cost better to buy a replacement light engine which comes with the DMD.
Apr 23, 2012 | Samsung Televison & Video
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots that dominate the screen
i think you do have a DLP Television because this happens a lot whit samsun DPL White spots in the screen.
is it like this?
if it's a yes? its the DMD BOARD you need to replace this part!
here are 2 links hope you can use them
http://www.discount-merchant.com/SearchResults.asp?Search=dmd%20board
http://www.partstore.com/Part/Samsung/Samsung/BP9601670A.aspx?s=froogle
Nov 03, 2009 | Samsung Televison & Video
White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Aug 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Aug 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots are just emerging on my 50 inch Samsung DLP TV everyd
the problem is in the DMD Board is it something like this?
usually this happens to Samsung DLP...
here is a link where you can find a DMD Board Good luck
you will need your part number
Aug 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-S4266W White dot problem
Its the DLP IC chip itself that is bad. The DMD board is where the chip resides but if you order a board, it will come without the chip. Its not cheap and the replacement is tricky because the DMD board must be removed and then an alignment of picture centering will be necessary.
michtech
Feb 12, 2009 | Samsung HLN5065W 50" Rear Projection...
Try here:
Feb 02, 2009 | Samsung HLN5065W 50" Rear Projection...
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLN567W 56" Rear Projection HDTV Logo
2,557 people viewed this question
Jerry Greenberg
Jerry Greenberg
