Question about Bosch HMV9305 Microwave Oven
The microwave When I hit start or "easy cook" the microwave isn't cooking at power level #10. I might not be cooking at all although it goes through the motions. It used to default to power level #10. Is that something that can be programmed in?
  • 1 more comment
  • gkronick Aug 02, 2008
    Thank you for your inquiry. The microwave does everything but heat. The light and turntable work in a normal manner. I have unplugged the microwave and reset the clock...no change. When I first placed my request I was able to manually set the power level but now, that doesn't work. The noise the microwave makes while "cooking" hasn't changed. The microwave is 2 years old. Thanks again, Gary Kronick
  • William Miller
    William Miller May 11, 2010
    So when you try to set the power level at something other than default full power, you would use a "power level" pad?
    And when you press that does it beep or does it act like that pad is not working?
  • William Miller
    It should still default to power level 10. If you're not sure, try a hard reset.
    Unplug it from the power line for a minute, plug it
    back in, set the clock, then try again.
    Otherwise, Do the inside light and turntable come on when you try to cook?
    Is it making any unusual noise or is it louder or quieter than normal?
  • Bosch Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
How do I set the power at 50%?
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
Mar 20, 2015 | GE Profile Spacemaker XL 1800 36"...
How do you change the power level?
On most brands, you enter the cook time, then press the "Power Level" key, followed by the using a single digit key for the desired power percentage, then hitting "Start".
EXAMPLE: Too cook for one minute at 30% power:
Time Cook > 1 > 0 > 0 > Power Level > 3 > Start
A possible alternative key combination may be:
Time Cook > 1 > 0 > 0 > Power Level > Power Level >Power Level > Start
Here is a guide to power levels:
May 21, 2013 | Rival Microwave Ovens
How do change the power level?
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
How to set microwave 50%
You have to put the cook time in first and then you press the power level button (just below the number 7 on the keypad) and put the power level in. The choices are 1 through 10. Fifty percent is probably power level 5. Once you have put in the power level, just push the Start button and it will start cooking.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I can't enter a specific cook time. only goes 1 - 6 minute. the express cooking times
hit power then select the power setting you want to use 1-10 then enter the specific amount of time you want your food cooked for up to 99 min. then hit start you should be good to go =)
Jan 23, 2011 | Cuisinart CMW-100 Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
How doI change the power on my microwave?
  • Press "Time Cook" or "Micro Cook."
  • Enter cooking time.
  • Press "Power Level".
  • Select a desired power level 1-10 (default is 10).
  • Press "Start"
Jul 06, 2009 | GE JES1855 Microwave Oven
How do i change the power on my microwave
  • Press "Start"
Jul 06, 2009 | GE Microwave Ovens
Howm do I reduce power down to 50%
First enter the cooking time just like normal, but then you hit the power button and then hit the digit indicating the power level you want. THEN hit start and it will start cooking.
Mar 08, 2009 | Danby DMW119 Microwave Oven
Bosch HMV9305 Microwave Oven Logo
99 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
