Question about Sub-Zero 632 / S
Subzero 532 ice buildup in frig
I have ice building up in the refrigerator at the point where the tubes enter the coils. This will then fill the back wall with ice. Is this a leak?
  • 1 more comment
  • ptmtvrm Aug 06, 2008
    subzero 532, the refrigator coils had ice just on the top three coils of the evaporator. its been three days since i cleaned it and still does not seem to want to get to 40 deg. there is no defrost in the frig, so whats my problem?
  • brendan732 Aug 12, 2008
    i have the same problem-right above the veggie drawer i have frost on the back wall- what is the problem? not cold enough
  • Marat Brikov Apr 25, 2017
    check this video
    Habit-Forming:
  • 41 Answers
Not enough refrigerant in sealed system or/and restriction in capillary tube.
HTML clipboard http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Posted on Aug 19, 2008
  • JerryLibckne Apr 25, 2011
    Thanks a lot! This is exactly what's happen with our Sub Zero fridge - restriction. Has been repaired. Thanks again! Jerry
How do I fix the ice maker fill tube that popped off of the back of the frig? I have a GSS25LSWA SS GE frig. I tried to stick the tube back in and get the adhesive to hold but i keep getting trickles of...
Make sure that there is not an ice build up inside the maker at the point where the water enters. The fill tube should not be under pressure. When water is called for a blockage will cause it to leak.
Feb 11, 2015 | GE Refrigerators
Magic Chef refrigerator, model RB214RFV: Freezer and frig not staying cold enough. Ice cream in freezer soft...frig thermometer in frig reads 50. Changing settings on dials does not seem to help.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 16, 2011 | Refrigerators
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
I have a subzero model 532. I turned off my
its quite possible that your fill tube is clogged with a bit a ice
Oct 09, 2009 | Refrigerators
Refrigerator icemaker won't work and refrigerator fills with wate
check your fill tube you might have an ice build up on the end
the fill tube is where the water dumps into the ice machine
Oct 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
SubZero 690: Frost builds up on ice chute flapper door
you have a bad seal, Take a dollar bill and slide it in between the door seal and the frig. slide it up and down to see if if has drag on it. If you find places it dont touch loosen the screws and adjust the hinges till it fits tight. In some cases you might have to tweak the doors if they need it.
Aug 11, 2009 | Sub-Zero 690 Side by Side Refrigerator
SubZero fridge problems
Ice buildup on the back left wall is the sign of an evaporator leak. Not something you can fix yourself, at some point it is going to be completely out of gas, I would call for service now
Apr 07, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Frig side not cooling properly
just the upper part? you are lw in freon pression are arond 36 cut in 16 cut out. 2 option replace the evap or in your case add freon> r 12 or remove all old 12 and use 414 ...... good luck.... LEAVE A COMMENT IF IT WAS GOOD FOR YOU
Jul 21, 2008 | Sub-Zero 632 / S
Water acculation in refridgerator.
I had a similar problem with my old hotpoint frig (top freezer, bottom frig). the defrost cycle would come on and melt the ice, but since the drain plug in the back of the freezer below the coils would eventually freeze up closed due to ice accumulation. It got to the point I had to shut down the whole unit and leave it open for around 8 hours to let it naturally melt the ice in the drain tube. I hear a gurgle sound and then a sound of water flowing, so I knew it was now draining again.
Jun 08, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Sub-Zero 632 / S Logo
1,002 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
