Question about Emerson Quiet Kool 10GV13 Air Conditioner
Need new filter
It's a foam filter with six compartments encased in plastic frame which is a slide out filter. The dimentions are 13" X 8". Cold you please advise me. I would greatly appreciate it as the air conditioner is old, but still reliable. My e
mail is Boland41@att.net and my name is Carol. Thank you. This is a Emerson Quiet Cool unit.
I went into Emerson air conditioner parts and they listed all the different filters and I was lucky enough to find the right filter , so I ordered it.
Posted on Jul 31, 2008
  • 7 Answers
Could you please share the model number of the one you ordered, as it sounds like the one we need? Please mention if you went to store or to web site.
Posted on Aug 16, 2008
No solution, just the same problem. I need the exact same filter, but cant find it with the information Boland41 posted. Can you help us by giving the store's name or phone number where the filter was found.
Posted on Aug 19, 2008
Wiring an accessory in passenger compartment
Fish your ground wire down to the driver's side underneath the dash. There you will find all sorts of metal connections to the frame. Just loosen a screw or nut, and slide the wire and connector underneath and tighten. Look around the fuse box, there should also be a ground connection somewhere there. You can also splice or tap into an existing ground wire.
May 14, 2015 | 2004 Volvo S40
How to change air filter
You talking engine air filter or cabin filter? Engine air filter is located in air box in engine compartment.. unclamp , open box , remove old filter, wipe out box, replace new filter , reclamp box.
Cabin filter located under cowl just below windshield. remove cowl bolts / plastic rivets. pull off cowl .. filter is in center and slides out like a drawer.. slide in new filter and replace cowl.
Feb 12, 2015 | 2002 Land Rover Freelander
Well the error message states that the mx310 ink bucket absorber is full and i cannot print\copy...
This is a reoccuring problem with cannon printers:
The print heads inside your Canon printer can become clogged and dirty over time, both from dried ink and dust particles. Each Canon printer includes a self-cleaning utility that automatically brushes off excess ink. While the feature keeps your printer running smoothly, it also fills up the foam ink absorber inside the printer. When the absorber is full, your printer displays an error message and won't print. To fix the issue, you need to clean out the absorber and reset the printer's ink absorber code.
Difficulty: Moderate Instructions Things You'll Need:
  • Gloves
  • Bowl
  • Soap
  • Paper towel
  1. 1
    Grab the plastic lid at the middle of the Canon printer and lift upward so the printer's internal compartment is visible. Wait five seconds for the ink carriage to slide over from the right side of the printer.
  2. 2
    Locate the square rubber frame at the far right end of the printer that houses the ink absorber. Grip the frame and pull it slightly toward you until it detaches from the printer. Pull the frame to the left and lift it out of the printer. Unplug the printer's power cable.
  3. 3
    Pull the two foam ink absorber segments out of the rubber frame. Place all three pieces in a bowl filled with warm water and soap. Gently scrub each piece to release the absorbed ink.
  4. 4
    Dry off the two foam ink absorber segments and the rubber frame. Set them on a paper towel and wait for each component to completely dry. Slide the foam ink absorber segments back into the rubber frame.
  5. 5
    Position the rubber frame back inside the right side of the printer. Press the frame onto its seat until it locks into place. Push closed the plastic lid.
  6. 6
    Hold down the power button on the printer's control panel as you plug in the power cable. Release the power button and wait five seconds. Tap the power button again to reset the printer's ink absorber code.
Read more: How to Clean a Canon Ink Absorber ' eHow.com http://www.ehow.com/how_7920357_clean-canon-ink-absorber.html#ixzz1EkisP5cs
Feb 23, 2011 | Office Equipment & Supplies
My vaccume has little suction
Hello :
1: Check that the Dyson's brushbar knob is turned to the "Carpets" setting for vacuuming non-delicate and raised pile carpet. Vacuuming carpet on the "Bare floor" setting usually leaves a telltale single wheel mark on the pile, and pickup is severely limited.
2:Locate the removable filter on the side of the vacuum. It will be marked with a raised circular representation.
3:Press down on the release button with your thumb as you lift filter housing up and out
4:Examine the filter for debris. Wash the blue foam and yellow framed filter in cold water. (See Tips section.) Let dry for 12 hours. Do not wash the outer filter housing that snaps into the vacuum; simply wipe clean with a dry or slightly damp cloth. Replace the filter when completely dry.
5:Locate the airway inspection valve on the opposite side of the vacuum. Press the release button as you lift the valve up and away from the machine.
6:Remove any debris or clogs you find inside.
7:Use a soft cloth to clean up lighter debris and completely clear the airway valve.
8:Tip the Dyson vacuum over to find the U-bend at the back of the unit. Press the release button as you pull the U-bend down and away from the machine.
9:Inspect the U-bend and remove debris. Be sure to line up the release button as you snap the U-bend back into place.
10:Check all removable pieces to be sure they are attached properly and snapped correctly into place. The soleplate should be flush with the cleanerhead.
What you need for this :
  • Large slotted screwdriver
  • Scissors
  • Washcloth
  • Soft cleaning cloths
  • Household surface cleaner, safe for plastics
  • Crochet hook or similar long-handled tool
Warning :
Unplug the vacuum before doing any troubleshooting. Follow all manufacturer's instructions and warnings. The yellow encased filter and blue foam filter pad can be submerged and rinsed in cold water only. Do not use detergent. Do not wash or dry in dish or laundry machines. Do not dry in the oven or microwave.
PLEASE RATE !
Apr 23, 2010 | Bissell 3576 CleanView II Bagless Upright...
There is no suction to our Dyson animal (purple-approx 8 yrs old)
Hello bnsbryan :
  • Scissors
  • Washcloth
Warning :
PLEASE RATE !
Apr 22, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hi i have a dyson animal allergy and lately when i turn its normal for about 3 seconds and then it makes a large sucking sound its still working ok.but not lifting up as good.its about 5 years old now.any...
Hello :
  • Scissors
  • Washcloth
Warning :
PLEASE RATE !
Apr 20, 2010 | Dyson DC08 Hepa Allergy Bagless Canister...
We have a Emerson Quiet Kool air conditioner in a camping trailor. It is old. We need a new filter. The filter is close to the mesurements listed by Boland-41. The exact mesurements are 81/2 by 131/4 and...
you can actually make a filter for a lot cheaper,
anyhardware store will carry the filter material on a roll, or bolt, just but the thinnest stuff and cut it to desired size.
many times I have bought Mezlin from a Crafts store, it is very good filter, and has almost the exact permeability as most of your ac filters
hope this helps
Oct 19, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Air filter replacement
Per Hondacarforum.com
"look for your air filter box. its a big square box on the right hand side of the car under the hood. you cant miss it. ther should either be clips or screws holding the box together. you have to get the top off of it to get to the filter... just replace the filter, and put the top back on and ur good"
per Chinogang Senior Member
May 06, 2009 | 2004 Honda Civic
Shutting off due to overheating
The foam style filters they sent you go in the top of the vaccume above the canister. There is a sticker in the back of the canister compartment indicating an orange lever in the top of that compartment. This releases a plastic retainer with the foam filter in it. Mine was so caked with dirt after 1 year of use it took a while to clean it up. I thought the vaccume was done for in only a year.
Jan 13, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Foam filter fabric
Yes you can buy it in hardware, just cut it to fit in the frame.
Feb 26, 2008 | Friedrich QStar SQ06J10 Air Conditioner
Emerson Quiet Kool 10GV13 Air Conditioner Logo
240 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
