Question about Toshiba Tecra 8200 Notebook
Laptop monitor Suddenly the screen went dark on my Toshiba Laptop. I connected my laptop to a regular monitor and it works fine but I can not see anything on the laptop screen. I have had this laptop about 7 years. Can it be repaired inexpensively? It works great otherwise.
  • 2 more comments
  • Anonymous Sep 08, 2008
    screen is black can barley see icons
  • jrlopez2001 May 11, 2010
    please eliminate password with star laptop
    chande harddisk diagram
    wath or explain change harddisk
I replace the screen and inverter board and it still does not work
Posted on Oct 20, 2008
    Genius:
  • 2,028 Answers
This will be a problem with either the screen or screen inverter. Screen or inverter replacement is fairly easy, and you should be able to do this yourself. As far as pricing the screen or inverter, try Ebay. With this being an older model, you should be able to get a good deal on a screen and/or inverter on Ebay, and definitely a better deal than at a shop. If you will get back to me on the model, I can probably get you instructions and diagrams for the screen removal/replacement.
Posted on Jul 30, 2008
Why is there no display?
hi
can you plug in another monitor to the video plug on the side of your laptop?
if the monitor works but your laptop screen stays dark your laptop screen needs to be replaced .
If the monitor is also dark then the LCD screen is ok but the inverter needs to be replaced
25717570-m35oz4jvdfvvmght4a51n0jl-5-1.jpg lcd connect to laptop
25717570-m35oz4jvdfvvmght4a51n0jl-5-3.jpginverter
25717570-m35oz4jvdfvvmght4a51n0jl-5-10.jpglcd screen replacement
cheers
May 28, 2015 | Toshiba Computers & Internet
Hi, I have a sony vaio vpcej3t1e laptop. Suddenly the screen went dark. The images on the screen could be hardly seen. I opened the screen, removed the connector and replaced it again. The screen now...
Connect a known working monitor to the the video output terminal of laptop. If that works then your screen is bogus. If it does not work then the laptop video circuits have an issue.
Apr 09, 2017 | Computers & Internet
Toshiba Qosmio F25-AV205 screen keeps going black
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 14, 2011 | Computers & Internet
I have a toshiba c655d but I the screen is too dark, when I connect an external monitor it works just fine. Any ideas?
Hi boris jurado...
Sounds like your LCD is faulty, if it works with another external monitor, then that is normally the problem.
You will need to change your LCD to correct this problem.
Please take time to rate me
Aug 23, 2011 | Toshiba Satellite C655D-S5080 Laptop
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
Screen went black
sounds like your monitor is shot or one of the connections in the back hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Screen went black
I don't know. I've never actually replaced parts in a monitor. If the bulb is expensive, it might be best to buy a new monitor. They're cheap nowadays. Or you can check if there's warranty on the monitor and it can probably be fixed for free.
Apr 20, 2009 | Acer X221WSD Monitor
Screen
Just turn the monitor off and on,,it should cure the problem,,also,,,tap the space bar on your laptop,,,,also,,you may want to change your settings on your laptop to prevent it going into sleep mode, or standby state,,which is what is causing this problem with your monitor.
Jan 19, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
My toshiba laptop screen changed color
connect an external monitor (crt or flat panel monitor) at the back of your laptop and see if the display is fine. if the display is fine on the monitor then it means to say that the lcd backlight is not working properly.
Oct 07, 2008 | Microsoft Windows Vista Ultimate Edition
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
Toshiba Tecra 8200 Notebook Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
