Does anyone know how to change the time on Grande Fiat Punto 2007 clock
Probably the fuel pump case cracked, or the o-ring sealing the pump.You need to find the fuel pump , on the trunk floor, or under the back seat (you wasn't specific about the model).Then you must check what's wrong with it.The best way is to leave it visible while You're pumpin' the gas. Good luck.
The fuel tank has lines that go out of it for different jobs. One of this plastic lines helps the gas fumes to breathe out in to the atmosphere throu a filter, so if this line is clogged for some reason no air can get out when you pump the gas in, so it spills it out. Locate this line and replace or unclogge it and hopefully this will cure you problem
