Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Dell UltraSharp 1800FP is black on start up but green light is on
Every day when i turn on my computer and monitor, the monitor stays black, but the green light turns on. I have to unplug the power cable and plug it back in a few times before it starts to work. When its doing this, the power button in the front doesn't work either, any ideas what the problem might be?
  • 1 more comment
  • jeff98air Aug 17, 2008
    I now have this problem with my 1800FP after a power outage last night while the monitor was on. I have the monitor on a (cheap) surge protector, but the breaker didn't even trip. Now, no matter what I do, the green power light stays on, but the screen is blank. I have tried unplugging the power and video cables in different combinations, but still no luck. Is it likely that the power outage fried something? Thanks!
  • Anonymous Sep 06, 2008
    when i star de monitor green light is ok but the screm stiil black so after 5 minut i have to press the i/o boton to get the screm on
  • tryingtofixi Oct 29, 2008
    I have a similar problem with the 1800FP monitor. when i boot the computer the monitor flashes the box that says "DSUB power saving" mode and then goes into perpetual sleep mode, with the LED indicator remaining yellow.
    When I initally booted the monitor, it worked for a few minutes, then I pressed to see the menu (to adjust the colors) and it stopped working.
    any thoughts on what the issue might be?
I had the same problem i found out it was the inverter i replaced it and it was like new. i do have 2 inverters if you are intrested
Posted on Sep 03, 2008
4 Suggested Answers
  • 14 Answers
SOURCE: dell ultrasharp blinks on and off
It could be a setting problem, power saver setting, or a mode that the monitor does not really support - things like refresh rate - or actual hardware.
Easiest way is to borrow another like monitor, and say another video cord and see if the problem remains, or if a newer monitor says 'out of range' or similar.
Then, if you have a fancy video card,remove it and use something primitive. Not reading instructions is a big cause.
If its not a setting issue, and as the inverter board is ok; if the above description is correct, reseat the inner board connecting cables.(wood fires and seaside locations) If not that, a lucky guess might be the electros on the logic board.
Posted on Aug 28, 2008
skotkolr
  • 558 Answers
SOURCE: my dell ultrasharp 1800fp monitor keeps flashing
Inside there is a IC chip on the power pack that goes bad, replacement is called for also look for bad capacitors when you are inside looking around, those need to be replaced as well
hope this clears things up. dells third party who built these units did a rotten job on this model. that chip always fails.
Posted on Apr 05, 2009
remaker
  • 449 Answers
SOURCE: Dell UltraSharp 2001FP (Gray) 20.1" LCD Monitor
Most likely, this is failing "inverter."
The backlight of the monitor (that makes the image visible) is controller by a special chunk of electronics called an inverter. They tend to fail over time. The symptom is that the backlight either never comes on, flickers, or shuts off after a short period of time.
It is a moderately advanced repair job to change out the inverter, but you can usually get the part on eBay. Search for the exact monitor model number and "inverter".
The 2001FP has six lamps and the inverter is fairly expensive. You might be better off putting that money towards a newer monitor.
Posted on Apr 11, 2011
Does ultrasharp's 1800fp monitors have built-in speakers?
No built in speakers. There is a sound bar that you can get the attaches to the bottom of the screen to add speaers to the unit but it is sold separately.
Sep 26, 2012 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Green tint
Sounds like the monitor cable has a short or loose connection at computer or monitor side.
May 24, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My Dell 1800FP monitor went black
Confirm your cables did not work themselves loose. Try using a different power cable to confirm that it was not the cable. Finally try a lamp in the socket you are using for the monitor power cable, if you are not using a power bar but even then just to rule that out. If the only thing left is that your monitor is dead, you will need to recycle that one and purchase yourself another one. Sorry
Sep 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Feb 20, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
1800FP Dell Monitor Light continuously blinks no picture
I have made a solution to this and it can be found on my website here:
http://www.dorchestercomputerrepairs.com/1800.html
Hope this helps.
sparkyuiop
Sep 28, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP, green power light, black screen....
Its probably the inverter that lights up the screen that went bad.I have replaced inverter before with much sucess. If you feel comfortable opening the unit up I found one on ebay. Here is the link.
http://cgi.ebay.com/1800FP-LM181E06-FPD1830-18-LCD-Inverter-KUBNKM045A_W0QQitemZ300179625342QQihZ020QQcategoryZ74936QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Dec 09, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP - display leak - blue craziness
That one is going to take component level troubleshooting. It could be the power suply, but I might first suspect the video board.
Jan 02, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
162 people viewed this question
Alun Cox
