Question about U-Line Refrigerator Ice Maker
U-Line Model WCM48
Thanks for the input on my question.
Can you provide me with a step-by-step procedure for removal of the fill valve?
Do you know if U-Line (or another company) provides parts for this model? It's a discontinued model and I am not sure how old it is.
Any help is very much appreciated.
  • jlore Aug 08, 2008
    Thank you very much for the information. The icemaker is located at our vacation home and I won't be able to work on it for a couple of weeks. I'll let you know how I make out. Thanks, again.
  • jlore Sep 08, 2008
    I ordered the part and replaced it as you suggested.
    The ice maker is working great.
    Thanks for your help and I will definitely come back to this website for advice in the future.
    Novelist:
  • 116 Answers
Sorry for the delay in responding...
Most models have the valve located at the back of the machine on the lower left hand side(viewed from the front). You may have to remove the entire back cover via the hex head screws to get at it. (some models have the valve located behind the front toe kick panel.)
First follow the waterline to determine the location of the valve within the fridge. If it is at the front then the toekick panel will have to be removed. If there are no visible screws then it is most likely a clip on style. If there is a knob for temperature setting then the knob may have to be pulled off first.
If there is a smaller cardboard panel at the bottom rear of the fridge remove it and you should see the valve. If not then remove the entire back cover by removing the screws along the rear perimeter of the fridge. The panel may stick to the back of the fridge but gently pull and it will remove. The valve should now be seen and can be disconnected.
Be sure to unplug the machine first and turn off the water supply. There will still be some pressure in the waterline so have a towel ready.
The valve itself is available online, I think the correct one is located at: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=832567&PPStack=1
Just be sure to verify that it is the right one before ordering.
Posted on Aug 05, 2008
Throttle stuck wide open , all the time.
Since you didn't provide a year and model, I can only generalize. Make sure the buttery-fly valve is moving freely and not binding, then check the idle air control valve, if the idle air control valve is stuck open, the car can actually drive upwards of 40mph without stepping on the gas.
Oct 17, 2015 | Cars & Trucks
Machine is not filling with water at of the cycle
Welcome to FixYa.
Based on your description, "machine is not filling with water at of the cycle"...the issue is likely with the inlet/water valve.
**To remedy this you will need to replace the valve**
This is what to look for..i.e.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple. Double check with your specific model number to be sure.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Dec 12, 2010 | Bosch Dishwashers
Water doesn't fill in ice tray seems that the line is frozen
Hi and welcome to FixYa, I am Kelly. If the fill tube at the top rear of the unit is full of ice this is usually caused by the inlet water valve pssing water when it is supposed to be shut off. Here is what you can do to check and see if the inlet water vale is bypassing water when it should be closed.
1. On the back of the unit where the small plastic line connects to the fill tube that gouse from the rear of the cabinet to the ice maker remove the small plastic line. Plate the end of the line in a bucket or large pan for 8 to 10 hours with the ice maker OFF.
2. At the end of the period where you have the removed line in the catch basin / pan or bucket, check for water. If there is water in the catch basin the inlet water valve has failed internally either from age or debris on the diaphram seat.
Since you did not provide a model number, I can not pass you a source for replacement parts or EXACT troubleshooting procedures. However here is a manual that will assist you in trouble shooting:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
If your ice maker does not have the optical sensors use this link for ice maker troubleshooting:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Here are 2 links for replacement parts: (model number is required)
http://www.appliancepartspros.com/
http://www.searspartsdirect.com/
Here is one of 2 types if inlet water valve: (example only as no model number to reference)
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Dual-water-inlet-valve-kit-item-number-AP3085178.aspx
Thanks for choosing FixYa,
Kelly
Nov 20, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Mazda 3 code p0734
DTC P0734 Gear 4 incorrect (incorrect gear ratio detected) DETECTION CONDITION
• The PCM monitors revolution ratio of the forward clutch drum revolution to the differential gear case revolution when the following monitoring conditions are met. If the revolution ratio is below 0.6 or 1.25 or more, the PCM determines that there is a malfunction. Monitoring condition: - ATF temperature 20 °C {68 °F} or more - Driving in 4 GR in D or M range - Engine running - Turbine speed within 225-4,987 rpm - Vehicle speed 50 km/h {31 mph} or more - Closed throttle position - Differential gear case (output) revolution speed 35 rpm or more - None of the following present: DTC P0500, P0706, P0707, P0708, P0712, P0713, P0715, P0751, P0752, P0753, P0756, P0757, P0758, P0761, P0762, P0763, P0766, P0767, P0768, P0771, P0772, P0773 Diagnostic support note: • This is a continuous monitor (CCM). • The MIL does not illuminate. • The AT warning light illuminates if the PCM detects the above malfunction condition during the first drive cycle. • FREEZE FRAME DATA is not available. • A PENDING CODE is not available. • The DTC is stored in the PCM memory. POSSIBLE CAUSE
• ATF level low • Deteriorated ATF • Shift solenoids A, B or C stuck • Pressure control solenoid stuck • Line pressure low 2-4 brake band slipping 3-4 clutch slipping • Forward clutch slipping • Control valve stuck (Bypass or 3-4 shift valve) • Oil pump malfunction • PCM malfunction
Diagnostic procedure
STEP INSPECTION ACTION 1 VERIFY RELATED REPAIR INFORMATION AVAILABILITY
• Verify related Service Bulletins and/or on-line repair information availability. • Is any related repair information available? Yes Perform repair or diagnosis according to the available repair information. No Go to the next step. 2 INSPECT ATF CONDITION
• Inspect the ATF condition. (See AUTOMATIC TRANSAXLE FLUID (ATF) INSPECTION.) • Is it normal? Yes Go to the next step. No Replace the transaxle, then go to Step 8. 3 INSPECT ATF LEVEL
• Start the engine. • Warm up the ATX. • Is the ATF level within the specification? (See AUTOMATIC TRANSAXLE FLUID (ATF) INSPECTION.) Yes Go to the next step. No Add ATF to the specified level, then go to Step 8. 4 INSPECT SHIFT SOLENOID VALVE A AND D FOR CLICK SOUND
• Perform operation inspection. (See SOLENOID VALVE INSPECTION.) • Verify the click sound of shift solenoids A and D when applying B+ to each transaxle terminal. Note • The click from solenoid D is barely audible. Remove solenoids to correctly inspect if necessary. • Was a click heard from solenoids? Yes Go to the next step. No Replace the solenoid where you could not hear click sound, then go to Step 8. (See SOLENOID VALVE REMOVAL/INSTALLATION.) 5 INSPECT LINE PRESSURE
• Start the engine. • Measure the line pressures. Specification
Idle: 330-470 kPa {3.4-4.7 kgf/cm2, 48-68 psi}
Stall:
1,090-1,250 kPa {11.2-12.7 kgf/cm2, 159-181 psi} (Z6)
1,160-1,320 kPa {11.8-13.5 kgf/cm2, 168-191 psi} (LF)
• Are the line pressures within the specifications? (See Line Pressure Test.) Yes Go to the next step. No All ranges: Replace the oil pump, then go to Step 8. Any ranges: Replace the control valve body, then go to Step 8. (See CONTROL VALVE BODY REMOVAL.) (See CONTROL VALVE BODY INSTALLATION.) 6 INSPECT STALL SPEED
• Measure the stall speed in D range. (See Stall Test.) Specification
2,100-2,700 rpm (Z6)
2,000-2,600 rpm (LF)
• Is the stall speed within the specification? Yes Go to the next step. No Replace the automatic transaxle, then go to Step 8. (See AUTOMATIC TRANSAXLE REMOVAL/INSTALLATION [Z6].) (See AUTOMATIC TRANSAXLE REMOVAL/INSTALLATION [LF].) 7 INSPECT FREQUENCY OF INPUT/TURBINE SPEED SENSOR WHEN DRIVING VEHICLE
• Turn the ignition switch to the LOCK position. • Connect the WDS or equivalent. • Start the engine. • Measure the frequency of input/turbine speed sensor while driving vehicle under the following conditions: - Vehicle speed (VSS PID): 80 km/h {49 mph} - Drive in the D range, 4GR - Throttle opening angle (TP PID): approx. 25% • Was the frequency of the input/turbine speed sensor at approx. 1,200 Hz? Yes Go to the next step. No Replace the control valve body, then go to the next step. (See CONTROL VALVE BODY REMOVAL.) (See CONTROL VALVE BODY INSTALLATION.) 8 VERIFY REPAIR OF DTC P0732
• Make sure to reconnect all the disconnected connectors. • Clear the DTC using the WDS or equivalent. • Start the engine. • Warm up the transaxle. • Drive the vehicle under the following conditions for more than 5 s: - ATF temperature: 20 °C {68 °F} or more - Drive in the D range, 4GR - Throttle opening angle (TP PID): 0% - Vehicle speed (VSS PID): 50 km/h {31 mph} or more • Are any DTCs present? Yes Replace the PCM, then go to the next step. (See PCM REMOVAL/INSTALLATION [ZJ, Z6].) (See PCM REMOVAL/INSTALLATION [LF].) No Go to the next step. 9 VERIFY AFTER REPAIR PROCEDURE
• Perform the "After Repair Procedure". (See AFTER REPAIR PROCEDURE [FN4A-EL].) • Are any DTCs present? Yes Go to the applicable DTC inspection. No DTC troubleshooting completed. click here to refer to this reference.
if you need further assistance please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 31, 2010 | Mazda MAZDA3 Cars & Trucks
Whirlpool heavy duty super capacity plus machine slow to fill.
This problem is commonly attributed to a water inlet valve that has become clogged with sediment or calcium deposits over time. If you live in an area that has hard water, or if you use well water, this is a common problem. You can remove the valve and attempt to clean it by soaking it in a 50/50 solution of distilled vinegar and water, or you can simply replace it all together. If you're going to go the route of removing the valve, it makes better sense to replace it, rather possibly having to repeat the steps again if cleaning the valve doesn't work. The following link explains how to access and replace one:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts can be purchased at any of the following web sites:
pcappliancerepair.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. If you do not wish to order parts on line, look up the part numbers on the Sears site and check with your nearest appliance parts retailer. These is a common part that may be commonly found in their in-store inventory. The average cost is about $30 - $35.
If you DO wish to attempt to clean the valve to save some money, submerge the valve in a 50/50 solution of distilled vinegar and hot water for about 30 minutes and flush with clean water. DO NOT submerge the electrical connections.
You may also try any number of calcium, lime and scale removers on the market. CLR comes to mind as a good product, but use in a well ventilated area. It has some very strong fumes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Mar 18, 2010 | Washing Machines
My toilet fills very slowly and only half way
There are multiple things to diagnose on a problem of this nature. I will give you a starting point, and you can work from there. If you need further steps, let me know. It may be something as simple as debris caught in the diaphragm of your fill-valve. This is not uncommon. The top portion of your fill will pop off, but you must shut water to the tank off first, before removing the cover. Underneath the cover, you will see a black rubber diaphragm. Remove this diaphargm, and slowly crack open the shut off valve just enough to start water flowing. If you notice any debris come out, your problem is solved. Reassemble the fill-valve, turn water back on. If this is not the problem, Your fill valve may just be bad. They are relatively inexpensive. However, before buying a new fill valve (assuming that step one did not solve this problem for you) Turn the shut off valve back off. and remove the supply line going to the toilet. Get a bucket and aim the supply line into the bucket. If this is not a flexible supply line, this step will not work. However, if it is flexible, point it into the bucket and turn the shut off valve on. If you have adequate pressure at this point, it is definitely your fill valve inside the tank. If there is not adequate pressure, it starts getting a little more complicated to diagnose. However, I can still walk you through those steps as well, but start where I recommended, as this is most commonly the problem.
Nov 20, 2009 | Kohler Cimarron Comfort Height elongated...
Tub fills when machie is off
You either have a water inlet valve that is leaking by and filling the tub slowly overnight. Or, you may have a siphoning issue that is causing water to be back fed from the drain line. Here's how to determine:
Shut your water taps off when not in use and monitor for several days. If the tub remains dry, then you know you have a water SOURCE problem. If the water fills the tub with the water taps turned off, you have a DRAIN problem.
If you need to replace the water inlet valve, follow these steps:
1. Turn off the water taps and UNPLUG the washer.
2. Remove the water inlet hoses from the back of the washer.
3. Remove the top panel of the washer by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
4. The water inlet valve is located in the left rear of the washer (as viewed from the front). Remove the dispenser hoses from the inlet valve and the electrical connections.
5. Remove the mounting screws that hold the valve in place and it will come out of the machine.
6. Reinstall new valve in the reverse order of the steps I provided to you.
If you believe you may have a siphoning problem, the following link explains what siphoning is and how to correct it:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you have any questions about any of the information I provided, or if you need assistance in locating parts, please let me know. I hope this helps you.
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to access filter for kenmore elite front load washer
To access the pump drain filter, follow the instructions in the link provided:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
It is recommended by the manufacturer that if the pump still does not operate correctly after cleaning, to replace it. It does not take much to damage the motor and impeller of these small drain pumps.
The water fill problem is usually caused by a water inlet valve that is not shutting off properly. To access the fill valve solenoids follow these steps:
1. Unplug the washer.
2. Remove the top panel of the washer by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
3. The inlet valve is located at the left rear of the washer (as viewed from the front). This is where the fill hoses attach.
4. A resistance reading of the valve solenoids should be between 750 and 850 ohms.
If you live in an area that has hard water, or if you use well water it is common for sediment and/or deposits to accumulate in the water inlet valve and cause problems with either filling or shutting off. you can attempt to remove the valve and clean it to see if this will correct the problem. Use white distilled vinegar to submerge the plastic portion of the valve in. DO NOT submerge the electrical contacts. Sometimes soaking in vinegar will dissolve and remove hard water deposits and sediment. If you wish to simply replace the valve, follow these steps:
1. Leave washer unplugged and remove electric connections to inlet valve.
2. Shut off water supply and remove fill hoses from the back of the washer.
3. Remove the dispenser hose from the inlet valve and remove mounting screw(s).
4. Install replacement valve in the reverse order of the steps provided.
Replacement parts can be purchased on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. All three sites have great service and offer competitive pricing. I would recommend checking with all three sites for the best price. Use your model number to initiate your search.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
U-Line Model WCM48
You can try to advance your icemaker by removing the white cover on your icemaker and turn the smaller gear counterclockwise to advance the icemaker. When the icemaker starts wait until the ejector blade gets to 10 oclock position this is where it calls for water. The test would be unplug the coil on the valve and put a meter lead on each one. If you see 120 volts then replace the valve. If you dont see it it could be the water switch inside the head of icemaker.
Aug 05, 2008 | U-Line Refrigerator Ice Maker
Fill doesn't shut off on Model WCM48
If it is just dribbling then chances are that there is debris in the fill vale preventing it from closing fully. Since it does not seem to flush out on its own then a new valve will likely solve your problem.
Jul 28, 2008 | U-Line Refrigerator Ice Maker
U-Line Refrigerator Ice Maker Logo
267 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
