Microwave Ovens Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get to the cartridge to see if it is blocked in some way. I have reduced flow. This is on my kitchen faucet. American Standard Jasmine Kitchen faucet
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Mar 05, 2011
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1261552
Points
17064
You have to turn off the water and disassemble the valve from the top side. Check your screens at the discharge point, particles block there, also.
9helpful
5answers
I obtained a Grohe replacement faucet head (kitchen) - part number 46298IE). The box contains (besides the faucet head) two small round cylinders (white); one has a green end; the other is white with a...
Thanks for the info about the lifetime warranty, who knew? The two parts mentioned are flow control valves that get inserted at the base of the sprayhead, not the in the hose. The green one says "water care" which will restrict flow more than the white one. It's an either or scenario, not both. There is a VERY faint arrow that points up toward the top of the nozzle. Push it all the way up and reconnect the hose tightly. That's it. My replacement didn't come with a wrench, did that come with the original faucet?
One more thing, if you bought a house that has this and don't qualify for the lifetime warranty, don't get stuck paying $100-$150 for this part if you just need to replace the aerator. The gray head that the water comes out twists out with a wrench revealing the aerator. The part number is 13929 or sometimes referred as 1392900, $10-15, if you can find it.
1helpful
Just put in a new moen kitchen faucet, why does it have hardly any water pressue?
You might have a clogged aerator screen. Remove the aerator from the faucet and see if the flow is normal. You can rinse the aerator off if it's clogged. It's also possible the stops (shutoff valves) aren't open all the way. Sometimes, if they're old, they don't turn on fully again after you shut them off to put in the new faucet. If you still have low pressure after removing the aerator, you may need to replace the valves.
I don't know if the instructions mentioned it, but it's good practice to remove the aerator and run a faucet to flush the water line after installing it. There's usually a lot of debris that comes through at first. That's usually why you'll have low pressure in a new faucet.
2answers
Moen 7600 kitchen faucet leaking from around handle
You will need to replace the cartridge....
here is tutorial on how to do that...
http://www.ehow.com/how_7241891_do-repair-moen-7600_.html
If you find that the cartridge will not come out you may have to purchase a Moen cartridge removal tool... you can get them at Lowe's or many othere plumbing supply houses....
http://www.bing.com/search?q=moen+cartridge+puller&form=HPDTDF&pc=HPDTDF&src=IE-SearchBox
heatman101
I have a price pfister kitchen tap and it doesn' have a cap. how do i get the handle off to replace the cartridge
If this is the single-handle faucet I remember, there's a decorative hot/cold indicator on the front, a small half red/half blue circle. This pops out of the handle to reveal the retaining screw underneath. It's a hex-key (Allen key) screw but I don't remember the size. Once you've loosened the screw you'll be able to lift the handle off the faucet body to get at the cartridge housing.
We have a steadily dripping tap. Can you please help? thank you.
You don't say anything about what kind of faucet you have, so this may not apply. But if yours is the kind with handles you turn to control the water, you probably have worn-out compression washers. In this kind of faucet, water is shut off by pressing a rubber washer on the end of a threaded stem against an opening in the faucet body. When you turn the handle, you move the washer away from its seat and the water can flow. Over time the washer gets worn and no longer seals off the water. Also, the valve seat the washer presses against can wear and allow water to sneak past the seal. The result is that annoying drip or a steady trickle.
This site, among many others, shows how to change a washer and fix most drippy faucets. If you search for "repair a leaky faucet" you'll find lots of sites to pick from, including many with videos. If you faucet is not a compression type, a single-lever cartridge for instance, there are links to other repair procedures.
If your faucet is old and the parts very badly corroded and worn, you might want to fix the leak by replacing the entire stem as a unit. You can find replacement stems for most brands of faucet at big-box home improvement stores and at many hardware store. It's a little more expensive, but often much easier to unscrew the old one and pop in the new than to start trying to get the old washer off the stem.
A last tip: Whenever you do any work on a faucet, remove the aerator from the spout and run the water to help clear the line. If you just turn the water back on and run the faucet, debris that was kicked up during the repair can clog the aerator screen. Then you're left wondering why you get only a weak trickle or no water at all after you fixed the trouble.
We live in a house built in early 60's. Re; Plumbing to kitchen sink and dishwasher. On vary rare occasion the sink faucet will have decent water pressure. We have changed the water faucet with a Moen. As...
if this is the only place in the home where water pressure is a problem then the lines may very well be the issue. if you have low pressure throughout the home then there may be a problem with the main water supply in the home. if the lines are galvanized pipe then they may be restricted due to rust or other deposits forming on the inside of the pipe. unless you are good at plumbing then i would suggest having a professional come out and assess the condition of the lines.
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
1helpful
I have a Kohler Fairfax K-12177. The faucet is leaking, major leak, out of the back of the body of the faucet. It appears that its leaking from a manufactured hole.
I have a Kohler kitchen faucet with the same problem. I called their customer service (1-800-456-4537) and they are sending a new valve and vacuum breaker free of charge.
I have a grohe model 33 790 and it is dripping so i assume the cartridge needs to be replaced. how do i get the cover off to get to it [email protected]
You shouldn't have posted this in the microwave oven section - the 33790 is a faucet!
Facing the faucet, on the right (where the lever is) the en-cap is bayonet mounted - twist and pull.
To remove the cartridge, there is a key that needs to be pullet out from the cavity , the lever unhooked and the cartridge pulls out. The replacement o-rings and special oval seals are available from Guillen in Florida.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
