Indesit wia111 stuck on spin cycle - Washing Machines
  • Anonymous Oct 13, 2008
    Yes our problem is similar - the thing isnt accepting commands from the dial even after 1 minute poweroff reset. It start to fil and go through a cycle after returning power. An abslute pain.
    Problem Solver:
  • 5 Answers
OK - Try this:-
1. Position the dial on number 0 (off) and then unplug from the wall.
2. After at least 24 hours plug back in - hopefully the thing should have reset.
3. This is really important. Select a wool wash program (No 9) and allow it to complete the entire wash until the door lock light starts flashing to say it's finished.
4. Turn the dial back round to position 0 and all LEDs should go out.
That's it - The control board is reset and all should be well
In order to prevent re-occurance, try to avoid canceling programs mid-cycle. It's also a good idea to switch the dial to number 0 and switch the machine off at the wall when not in use if at all possible.
Please let me know if this works for you :)
Posted on Oct 31, 2008
2 Suggested Answers
SOURCE: my indesit washing machine wia111
is that the only way to restart this washing machine?
Posted on Jul 01, 2010
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
I have an Indesit WIA111 and the pre was/ wash LED light keeps flashing when machine is not on can you help
try the reset by unpluging it and plug it back after one hour.
check your manual for fault codes.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Indesit Washing Machines
Indesit wia111 no lights come on when switched on at powerpoint
Make sure you dont have it set to soak. if you click the timer one click at a time, does the wash/mach. do anything like wash:spin:drain etc. check that door latch for power out once closed. difficult to diagnose without all the facts
Jan 27, 2009 | Indesit W 123 Front Load Washer
Wia111
Turn the on/off knob to the position with the symbol I enclosed by a broken circle,.
This should turn it off.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit WA 115 Front Load Washer
It starts off ok but 5 mins in to the cycle (any cycle)all the lights start flashing and it just makes a sloshing noise but the drum is still.... .it an indesit wia111
Check the drain pump they haave a catch sleeve inside the drain line before the drain pump. Remove the lower front panel to access the pump and remove the large hose from the drum. Inside the hose is the sleeve, take out the sleeve and clean it.
Dec 11, 2008 | Indesit W 123 Front Load Washer
I have purchased a new door rubber seal(indesit W103) as the old one was split. i have removed the old one but cant work out how to put the new one on. It looks like theres a technique to it. please help
Fantastic walk-through, thank you! These instructions also work for the Indesit WIA111
Getting the seal back on is tricky - if you feel you have to really force in back on (like a tyre on a bike) then you are probably doing it wrong.
I found once I had the knack it was best to stasrt again in the least accessible place
Jul 30, 2008 | Indesit Washing Machines
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
1,783 people viewed this question
Top Washing Machines Experts
