DBX-1215 to Home Receiver
I want to connect a DBX-1215 to a Yamaha RX-397. Do I need a set of LM2B/U Device Matching Device to convert from Unbalanced to Balanced ? The DBX-1215 has XLR connectors. Should I get some XLR-RCA cables and use these to connect the Receiver and the Equalizer directly ?
  • hank003 Aug 02, 2008
    I'm sort of in the dark here. I've never heard of a PL55 Connector. I looked at the XLR-RCA cable at cablestogo.com and they state that these cable go from an unbalanced Output to a Balanced Input. Can you give me a source for the XLR-PL55 cables ?
    Thanks
You should need a XLR-PL55 connector that has balanced connections.The PL55 is stereo,so that there is a balanced connections.
Posted on Aug 02, 2008
Have a Yamaha RX-397 switched it on started smoking, switched it off straight away.
open u r RX-397 and see the main supply board inside it whare is u r main power cord is connected their is a capecitor of 200 to 400 volt it is burend so it smoking change it and enjoy
Feb 02, 2013 | Yamaha RX-397 Natural Sound AM/FM Stereo...
Rx-397 smoke came out
change it's main capacitor in main supply board inside RX-397 it is burnt so it smoks
Feb 02, 2013 | Yamaha RX-397 Receiver
Trying to hookup XM radio to RX-397; no sound. Which inputs should I be using?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-397-Receivers-manual/id/320ag614/t/2/
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Of course, if your XM device has standard RCA outputs, use RCA cables without adapters.
May 27, 2011 | Yamaha RX-397 Receiver
I have a Yamaha Rx-v367. I have the Wii console connected as shown on page 17 in the pitiful excuse for a manual that comes with this receiver; composite video (blue, red,green) hooked up to AV1 and the...
I don't think the Wii outputs an RGB signal, so you may not be hooking it up to the correct port. But in any case, if you look on the left side of page 13, it appears that this unit will not convert from one signal type to another, only pass them through to the matching output port. I'm still trying to verify that this is the case - if so, it's pretty disappointing because then you need to switch both the audio and TV inputs to change from one source device to another.
Dec 28, 2010 | Yamaha RXV367 Receiver
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
My 1215 equalizer produces a hum when inserted between the subwoofer output of the receiver and subwoofer amp. I am using the barrier strip inputs and outputs, rca tip to plus, shield to minus. I have...
Wild guess - I had something just like your problem (including consumer dbx components) and it was ONLY with the track lighting turned ON. Replacing the lighting control DID NOT help but the problem up and went away by itself.
Sometimes hum can be defeated by rotating the orientation of a single power plug.
Just wondering: WHY do you feel the need to EQ the sub beyond its own controls? Though I don't have not pro-gear, I'd use a dbx-120 instead and save the EQ for something more in tune (pardon the pun) with its capabilities.
May 21, 2010 | DBX 1215 Home Equalizer
I recently bought a RX-V465 receiver and I need to know what type of speaker terminal jacs are present in the receiver so that I can convert my old SONY Home Theater 5.1 speakers (DAV-FX500) which have a...
1 - As you already have it, take it out of the box and look at the back. You should be able to determine the connections from there. It is also in the owners manual.
2 - The receiver only supports 6 and 8 ohm speakers. Do not use 3 ohm speakers with it.
3 - The Yamaha website has instructions on how to check the firmware version and instruction on how to upgrade the firmware.
Oct 06, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V361 DVD cuts off w/ check SP cable message
This message means that speakers are not connected properly. What is their impedance? What is the impedance set on the receiver via Advanced Setup menu (see manual)? Check if it is not short-circuited.
Try the receiver without speakers connected. If the message goes away, receiver is OK and problem is in the connection to the speakers.
Jun 04, 2009 | Yamaha RX-V361 Home Theater Receiver
YAMAHA RX-397
hi,
I'm still waiting your reply.
Sep 09, 2008 | Yamaha RX-397 Receiver
179 people viewed this question
 Grubhead
Grubhead
