Question about HP LaserJet 2420 Printer
Paper tray 1
The printer wont use the letterhead paper that I put in tray 1. It will only use it if I open tray 2.
  • 138 Answers
Print a configuration page from the menu. Look at the tray set-ups. Sounds like you have tray 1 set to casette. Change it to "first" and the size to "any". The printer will then pull paper from tray 1 any time you put something there.
Posted on Aug 19, 2008
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
When printing in color, the color runs
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb), OHP transparencies, postcards*, letterheads,
colored paper, envelopes, label sheets, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray
Jul 13, 2010 | Samsung CLX-2160N All-In-One Printer
Default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Dec 09, 2009 | HP LaserJet 4200 Printer
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
May 30, 2008 | Konica Minolta bizhub C250 All-In-One...
When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t want that to happen cause we print in bulk! When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t...
Hello Uncle123,
I don't have a user manual at my fingers, but you can go into "additional functions". I don't recall if it is within the"common settings" tab or "copy settings" but you can designate any paper tray to be "unique". For example you can designate tray 2 as "colored paper, or recycled paper" .In which case, if you are feeding from tray 1 and it runs out the copier now knows that tray 2 has a type of paper that is different than the current run.Even if the paper size is the same. I hope this helps. Take care. ..............................spinal.........................
Feb 22, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Printing using various trays
Yes
Set tray (3? ) or other non standard paper type trays to type setting of letterhead and set normal paper tray (2) paper type to plain .
You do this on printer keyboad find menu then find paper handling, tray xxx, paper type. xxxx...set or tick
Via operations panel you can also printout current settings too to see if you have done the change if you do one before and after
Then test,
There are other settings on your printer that can effect this and driver configuation and doc type setting on pc that can effect this also but try step above first and report back if still having issues. Is it run by a server? Do you abity to change driver settings on your pc?
Oct 19, 2007 | HP LaserJet 4350 Printer
HP LaserJet 2420 Printer Logo
164 people viewed this question
Seeker5211
Seeker5211
