Remote does not agree with the unit display on TAS-24 unit.
Called the company
Posted on Aug 01, 2008
  • 1,420 Answers
Near the battery section on the remote you will find a small hole only a paper clip will fit in. This is your reset. Try resetting the remote. You will have to reprogram it.
Posted on Jul 31, 2008
Aiwa XR-EM50
This was easy.. download the manual here:
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
Replacement Remote
EMAIL: for parts / remote controls
Jun 02, 2013 | Turboair Heating & Cooling
The remote for my Tubo Air TAS-12 doesn't work. Are there batteries inside or do I need new one?
does the remote come on? if not then yes i suggest changing the batteries, some remotes have a slide that covers the buttons pull it down and take it off you should see the batteries when that is removed, or some are at the back, let me know if that helps
Sep 24, 2011 | Turboair TAS-12 Air Conditioner
New turbo air unit installed in july 11 and the unit will not enter heat mode...not sure what to do...any help would be great
This could be a wiring, programming or a reversing valve problem...
Does the remote show that you are in heat mode???
Does the unit come on and run in cooling when it should be heating???
then it is a reversing valve stuck...
if you are not getting that much to happen then it is a programming or unit wiring problem...
Sep 17, 2011 | Turboair TAS-12 Air Conditioner
Bakit ayaw na bigla magwork nung remote nung LED TV namin. pero nagiilaw sya kaso kahit ano pindutin ayaw magwork.
Check mo tong video na ginawa q para ma-confirm kung ng-lalabas ba ng infrared signal ang remote control mo. Itutok mo sa cellphone camera mo ang sensor ng remote control tas pumindot ka ng kahit anong button. Me makikita ka na infrared light pag ayos ang remote control mo.
Inform mo aq kung ano nakita mo.
Sep 06, 2011 | Televison & Video
Unit aill not turn batterys in thr remote, (second set).Also can this unit be run manualy? My model # is TAS12VW/O
What is the manufacturer of your unit please?
the model # is coming back as invalid.
Aug 06, 2010 | Turboair Heating & Cooling
Owners Manual for Kenwood Car radio Model KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
The issue with the DV2000, 6000 and 9000 not booting, no display, no sound, no wireless is well known to HP- check their website. Call them and make them fix your computer. If they argue, firmly direct... Read it but finally I would recommend that you ask the manufacturer to replace your set with a different one and pay the difference. This series has lots of problems which will never get totally solved.....sodeep
Mar 19, 2009 | HP Pavilion dv9000z Notebook
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
