Question about Whirlpool LER5636P Electric Dryer
Whirlpool Dryer Model # LE7680XSW1
Dryer will run for a few minutes ( 5 - 15) then shut down, it may or may not start back up, It is heating up. just won't run long enough to dry clothes, Vent is clean. Unit is approx. 18 years old and have had no problems until now. Dry's 3 to 6 loads a week. Help will be appreciated as wife is not happy with me. Thanks David
  • smithdks Jul 30, 2008
    Yes, unfortunately went and brought a new dryer.
    Done this instead of putting money in the old one.
    Sergeant:
  • 260 Answers
David,
You have a pretty old dryer. Replacement is recommended because new dryers use less electricity and more than make up for the price with the savings on your electric bill.
However, if you still want to use this dryer, you will need to replace some internal switches. In order to guide you through that I recommend you use our premium service.
If you need to find a local repair service, please type your zip code into our repair service search engin located on our site.
Good luck,
CH
Posted on Jul 30, 2008
Kenmore dryer runs only for a few minutes
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Whirlpool Dryer Mod. # LE7680XSW1 over heats at end of drying cycle
check the vent first what cycle are you using ?
Feb 03, 2014 | Dryers
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Upon clicking the start button on the Dryer...the motor hums and does not turn the drum. After several attempts trying to engage motor from the start button...it then just clicks. Prior to this the dryer...
Good day,
Sounds like a bad motor. You access the motor from the front.
You can check bearings while you have it down. The only touchy part is getting the blower wheel off. Sometimes the are frozen, and have to be broken out.
Here's an excellent tutorial.
http://www.applianceaid.com/wpmotor-change.html
Feb 07, 2010 | Whirlpool Dryers
When I start my dryer, I have heat at first, but it shuts off after a short time for the rest if the cycle.
It sounds like you have a gas dryer . The coils on the burner valve need to be replaced . They get hot from the electricity going thru them , and one opens (shorts ) until the dryer cools down . It should then heat again for a few minuted , then stop heating but still run . Your timer will not advance either , if set on auto , unless dryer heats . Without the model number , cannot give you the part number , so take it with you to get the part . It comes with both coils in a pkg .
Oct 11, 2009 | Whirlpool Dryers
Dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Jul 24, 2009 | Whirlpool Dryers
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Hunting boots no no!
If you have one of those fubuloso wrinkle guard whirlpools, they will buzz and start back up on their own in the cool down portion of the cycle the idea being the 2nd timer will keep the clothes from wrinkling by buzzing and then coming to life for a few minutes. Then it waits 10 minutes and if you aint got the clothes out or opened the door then it will repeat.
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
341 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
