Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Can't get toner out of machine to install new one...
Hi there! So... let me preface this by saying I've changed plenty of printer toners in my time... I suspect that I'm just being a moron or something, but for some reason I can't get the toner cartridge out of this Canon 3300IR. I've followed the screen directions - move latch, pull out toner, but the back end of the cartridge gets stuck and won't pull completely free. I've fiddled around with all the knobs and latches I can see, is there something I'm not doing?
Thanks for your help!!
    Sniper:
  • 57 Answers
To change the toner on this machine you do not need to take the toner unit out of the machine completly. Toner is meant to be fed with that unit slided out of the machine. Be the case you need to take out that unit. Look below the unit and you should see a white plastic with one screw. remove screw and plastic. And the unit could be taken out easily after that.
Posted on Aug 03, 2008
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
Printer Status LED is Red and Drum Light is Yellow
Hi, this error shows when the corona wire is dirty, some times I clean the corona wire with a small screw driver pressing the corona wire down and slide the screw driver to the both sides also once you clean in the up I press from the side and slide the screwdriver after that with a cotton swab with isopropyl alcohol slide from side to side, or replace the drum unit and reset, if you install a new toner, there is a mechanic control for reset the printer toner counter, this only works the first time that you install the cartridges, for example If you install the cartridge in 1 printer and then move to other printer the other printer keep the counter for the old cartridge, if you are sure that your cartridge is new you need to open a return the gears to is original position in order to install in another printer.
Jul 26, 2013 | Brother HL-5240 Laser Printer
Toshiba E-studio 212 How do diserbleToner recognition sensor
Oddly enough, I just had the same problem with "OEM" toner. The chip on the toner bottle was not working correctly. I installed another toner & the bottle was detected. The bottles that did not work I throw out. You may want to try to return the bottles that are not working correctly.... Good Luck
Apr 11, 2013 | Office Equipment & Supplies
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
My Ricoh CL7000 is saying add toner magenta. But there is plenty of magenta in the cartridge. I've added toner and cleaned out everywhere I can get to. Any suggestions?
It could be a clog in the toner tube, but the most likely (and easiest to fix) problem is the magenta DV unit. Replace the magenta DV unit, turn the machine off and back on, and if it still says add magenta toner open and close the toner cover so that it can load toner, then your problem should be gone.
Nov 08, 2010 | Ricoh Aficio CL7000 Laser Printer
SAYS INSTALL CYAN BUT CYAN IS IN
kindly remove the the cyan toner and shake it and install it .if it not working then install new cyan toner.
Jan 22, 2010 | HP LaserJet 2840 Printer
Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Oct 27, 2009 | Minolta bizhub 200 All-In-One Printer
I have just changed my M-toner because it sayed "toner out" but it still says "Toner out"?
inset new toner or refile toner just install new toner and second is reset the toner chip
call for more infirmation :+91-9328015664
E-Mail:support@compudesk.in
Jul 15, 2009 | Epson AcuLaser C4000 Printer
Cartridge not detected
if the printer says toner not installed, then you have a dirty chip reader, remove pc drum and all toners, use pressure air to clean chip reader under the toner rack at right side and reinstall everything.
Jun 26, 2008 | Konica Minolta magicolor 2400 Laser...
543k toner sensor error
Your indication regarding the 100% does not necessarily indicate a damaged chip (sensor).
Many chips do not work by actually sensing the toner but by usage or other tricks.
We cannot be sure about what happened but replacing the drum and affected items
should solve the problem. Needed parts may be found at
http://www.inkfilling.com/toner-refill-OkiData--C5800Ldn.html
Jan 21, 2008 | OKI C5800dn Laser Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
173 people viewed this question
old marine
old marine
