Question about Cell Phones
Nokia n81 running a new battery down in 6-8 hours on standby mode
    Sergeant:
  • 260 Answers
Even if the battery is new, if it is not charged properly it can run down pretty fast. To reset the battery I recommend running the battery all the way down - charging the battery all the way back up to full - and then repeat. Also, make sure you do not charge the battery after it is full. Most phones or charge units have signals to tell you when the battery is fully charged. Do not charge the battery overnight.
These are the best ways to protect the life of a battery.
Posted on Jul 30, 2008
Why the battery drains off to one point in hour in Nokia N70 with out any operation? The same battery retains full power more than 24 hours when removed from N70.
i think that your battery's lifetime is over. try with a new battery. but make sure to buy an original battery. don't buy cheap chinese battery.
Nov 07, 2014 | Nokia N70 Cellular Phone
N81 8gb memory full
First make backup all the important files/data which is stored in your phone memory (C drive).And format it by typing *#7370# when your phone is in standby mode or follow Nokia Formating tips.I think that this will enough,but in case if this doesn't help Flash the phone.Thanks for visiting fixya
Mar 26, 2012 | Nokia N81 Smartphone
My nokia 6300 standby time is only 6 hours even w/ new battery
Update the phones firmware to V 07.21..U will get a better standby time.. :)
Mar 12, 2010 | Nokia 6300 Cellular Phone
Battery Problem for Nokia N81 8gb
I bought new nokia n 81 few weeks ago.its battery finishes very quickly.plz help me
Jul 06, 2009 | Nokia N81 Smartphone
My Dell Inspiron 1520 seems to use a lot of battery power, even when the lid is closed, and nothing is running. Is there any way to save battery power, without going into standby mode, or turning off the...
How long does your battery usually last? If it lasts 2 hours or more, that's normal for a notebook computer. The standby mode and turning off of hard drives is what notebooks are designed to do to give you more battery life. If you have to have it on and available all the time without going into standy mode, you'll need to get used to charging it every couple of hours. If you want to get more battery life, try the following options:
1) have the display turned off when not in use (this setting can be changed where you set up your screensaver)
2) turn off the wireless function (if available) when not in use
3) have the computer go to standby mode after 10 or 15 minutes of inactivity.
4) lower the brightness of your display
All of the above assumes that you're getting a decent charge and can use the notebook unplugged for 2 hours or more. Naturally, over time, notebook batteries wear down and don't hold a charge as well as they once did. If your notebook is a few years old and you're only getting an hour or so on a full battery, then it is probably time to invest in a new battery. If your notebook is new and you are getting this short battery life, contact Dell for a replacement battery as yours may be defective.
One last thing about notebook batteries. They are designed to be charged up and run down. If you leave your computer plugged in to a/c power all the time while you are using your computer, this greatly speeds up the wearing down of the battery. Whenever possible, you should fully charge your battery and then run the battery down to 10% or less before plugging it back in. This ensures that you get the most battery life on a consistent basis.
Hope this help. Please take a moment to rate the solution. Thanks.
Mar 11, 2009 | Dell Computers & Internet
N81
If you're talking about the normal lock code for access to the mobile standby mode, if you forgot it, then you need to go to the nearest Nokia center with proof of purchase to remove it. If you're talking about the NORMAL passcode for options such as formatting, then the default one should be "12345", sometimes it could be "00000", but if not, and you don't know what it is, you should also head to the nearest Nokia center to change it.
Nov 04, 2008 | Nokia N81 Smartphone
How to format my nokia N81 8GB phone?
either *#7370# fro the standby screen, and enter lock code, default is 12345
or when booting up, hold the call (green) key, 3 and *
alternativly try reset to factory from tools>settings>general>factory settings.. again default lock code is 12345
May 10, 2008 | Nokia N81 Smartphone
Nokia 6680 charge problem
with respect to your low Nokia 6680's low battery, what you need to do is to charge it while switched off for atleast 12 hours.  It is possible for the phone to have 200+ standby time afterwards but that is if its not used at all. You should also disable the bluetooth, as well as the backup ligthing if switched on as all these can dramatically reduce the life of the battery.
Sep 23, 2007 | Nokia 6680 Handheld
Cell Phones Logo
167 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
