Question about Garmin StreetPilot c550 GPS Receiver
My interswitch pin is missing
What do i do now to get it here
  • jaelito37 Jul 30, 2008
    my gps is lock and i forgat the pin number
  • 504 Answers
What is an interswitch pin? Never heard of any such thing on a C550. And the only way to unlock a PIN locked Garmin is to enter the correct PIN number or take the unit to the location at which the PIN was initially set. Your only other option is to send the unit to Garmin.
Posted on Aug 05, 2008
Why is it missing fuse pins in relay section of fuse box?
It's normal to see pins missing. They deleted the relay for O2's just ran them on a fuse. And if you don't have a rear blower, you wouldn't need that relay. They also started putting the blower relays in the resistor.
Mar 26, 2016 | 2004 Dodge Dakota
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
The dodge dealership said we needed a pcm, so we replaced it. Now, the transmission wont shift out of low gear. The pcm has 3 missing pins. Will this effect the transmission? I'm thinking we need to get a...
did the original pcm have thee missing pin, they may not be missing they may be left out in engineering, as far as the trans not shifting, was the pcm reprogramed because if you just installed out of a box it unlikly that it will shift
Oct 30, 2013 | 2004 Dodge Grand Caravan
Hard drive is missing a pin on the ide connection is or can it be fix or repaired or a way to get the information of the drive
IDE hard drives connectors are supposed to be missing one pin. That missing pin acts as a "key" to prevent connecting an IDE cable upside down.
Sample picture to show where the missing pin should be: remaker.jpg
Apr 13, 2011 | Computers & Internet
KK266 mother board (IWill) need a wiring diagram, usb is not being identified
Antec doesn't make mother boards, they make enclosures. The standard USB connection on the board is a 2x5 pin connector, with 1 pin missing. The end that has the missing pin, is the end that the cable shield is attached to.
Mar 24, 2010 | Antec Computers & Internet
Processor pins missing
Many CPU fit the same socket number. It depends upon how the CPU is wired internally on which pins it uses.
Mar 18, 2009 | EliteGroup P4VMM2 Motherboard
Electric on motherboard
Yes. usually. Most boards have pins missing. The board layout is for all boards,not all models. That is the reason that sometimes pins are missing. You will see layouts for other items(options) missing also.  Ido not have A drawing or picture of your particular board  though.
Feb 05, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Monitor is missing pins?
If the monitor is working correctly, there is no problem. Not all 15 pins are used, therefore there is usually two missing.
Jan 24, 2009 | HP Pavilion MX70 17" CRT Monitor
Bent or missing pin in game connecter
If there is a pin missing, call an expert or take it to an electronics store. There you should be given a replacement pin! Good Luck!
Sep 09, 2007 | Nintendo DS Lite Console
Garmin StreetPilot c550 GPS Receiver Logo
29 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
