The best way to do this is to shut the incoming water supply off. Open the closest cold water faucet to relieve the water pressure. Shut off the outlet valve. You will need a BB wrench. Push the RED pressure relief button on top of filter as you turn clockwise on the wrench. Lubricate the o-ring with silicone lube, clean filter housing and re-install filter. Only tighten housing hand tight.
RJ
