Question about Maytag Washing Machines
My top poading maytag (model AI 075 - AI 085-A3085) washer timer is not working. How to install it? Where is it located in washer? How much is cost of timer where can I get it?
  • 191 Answers
You can find the parts information from...
Posted on Jul 30, 2008
Maytag top load washing machine repair
It sounds like your Maytag (now owned by Whirlpool) Actuator needs to be replaced. Last year our Maytag Centennial top loading washer Model MVWC300XW0 would not drain all the water and cloths would be soaking still. Doing some online research, I came across some very helpful video regarding replacing your Actuator.
The only thing I would recommend to future installers is get your Technician Manual located just inside the case (front panel) first of your Washer. The Technician Manual is taped inside your washer in a plastic bag. Once you replace this Actuator part, I recommend that you run the Calibration cycle on your washer. It is needed anytime you replace a motor, motherboard or pump.
Here are two videos describing how to change/replace the Actuator but these videos are basically for the MVWC300XW0 model. I'm sure if you search for your model, there will be other videos as well.
Two videos on how to replace your Actuator:
2: (This is video that I viewed the most)
Best of Luck!
Jun 05, 2016 | Maytag Washing Machines
Maytag MAV 8260 AWW Does not work at all. No water flow, no spin (even when filled with water from hose) Does it have an internal fuse? Where is it located? Is the large timer switch the brain of the...
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Nov 02, 2013 | Maytag MAV7600 Top Load Washer
Washer is stuck on spin cycle and advance will not operate
Timer is not working correctly, look for a used time on Amazon, or Repair Cost about $100. new/used No bad to replace, take the top off, you will see the electircal connector, and hardware that holds a timer in place. Check to see that connector is pushed togeather good while your in there.
Dec 19, 2012 | Maytag Washing Machines
Our Maytag A 612 does not spin and makes a loud noise. It is cost effective to pursue repairing or not?
Hi and welcome to FixYa. I am Kelly.
You have one of the work horses that was built before Whirlpool bought out Maytag.
IF the base and cabinet are in good shape it just might be worth keeping. Not that I am partial or anything but I still have a 1980 model washer and a 1973 (A606) model dryer that work fine both maytags. They are still serving me well.
There are few things that can cause it not to Spin
1. The motor is not reversing (motor itself a problem)
2. The timer contacts have failed internally.
3. The brake is locked under the large pulley on the bottom of the machine.
4. The radial bearing under the transmission has failed and locked up. (posible source of LOUD noise like a roar) I would like a better explanation of the loud noise.
I would honestly invest in the cost of a service call to get an on stie evaluation of repair costs.
On a machine that age expect the following recomendations for parts replacement by the repair tech.
1a. Radial bearing
2a. Drive belts (2)
3a. Tub bearing
4a. Motor mount rollers
Other possibilites
a. injector kit
b. tub fill hose
c. timer
If he looks at it and comes up the with same needed parts list 1a - 4a above and a recommendation for repair.... Fix it because there are very few machines out there today that will perfom and last like your washer.
Thanks for using FixYa.
Jan 03, 2010 | Maytag SAV4655A Top Load Washer
Hi, your timer motor not working,(burnt) or could be mechanical fault in timer, but first replace timer motor, check for timer motor, give appliances store model & serial no. for washer, and let me know when you get it, i will guide you, to install it, yes you can, it's not that complicated. don't forget asked for timer motor. good luck.
Aug 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Where can purchase a new timer for my maytag atlantis washer.cost
Hello I would have to know the model number to give you a cost on the timer, You can buy a timer from Hope this helps :)
Jul 16, 2009 | Maytag Washing Machines
Washer wont cycle thru
There is either a kicker solenoid that fires every minute to kick a gear, or a tiny AC 60Cycle Induction motor in there that probably burned out. You will need to fix by replacing that solenoid or motor, or the entire timer.
A spider or bug could also nave gotten in there and stopped the motor rotating 60x a second, but if a solenoid it burned out.
Timers cost $30-80.00 and can be bought at Sears, or a good appliance parts store (online too) all you need is model and serial#
Good Luck
Mar 26, 2009 | Maytag Legacy MAV208DAWW Top Load Washer
My washer was working fine and now does not go through the cycles
the timer is not advancing by its self...defective timer replace..onthejob
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Maytag Top Load Washer Won't work automatically
yes, there is no adustment on the timer,you can go to sears .com click on parts put your model number in and get your part,cross check the price at repair clinic .com,every easy to install just has one wire connect jack,let me know how you do-mike
Oct 31, 2008 | Maytag PAV2300 Top Load Washer
Open Questions:
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
