Question about Electrical Supplies
Poulan Model 1950 Chainsaw
I found a small rubber vent part (among other things) in the gas tank of my Poulan 1950 Chainsaw. I have purchased a new gas intake filter and new fuel lines and would like to assemble, but don't know where the vent part goes.
Any help would be appreciated.
Les
  • 211 Answers
Hi
i think it is the gas tank vent who sets the pressure between interior and exterior of the tank.There is a hole in the gas tank.
regards savumihai71
Posted on Dec 16, 2009
How do i tell what "type" of Poulan Model 1950 saw I have
The type no. should be on the ser no. plate 1-8 there are small changes between the type no.s but they are all model 1950, is this the machine that you inquired about the sprocket? as that was not the model quoted in you first question!!!!
Jan 13, 2013 | Poulan 14" Chainsaw
Hi Sirs, I have a Poulan Woodshark model 1950. The gas lines deteriorated and I bought new ones, together with the primer bulb and the chain. Now I can't remember how to connect the lines. I need help....
The fuel line from the tank with the filter on the end goes to the carb inlet, closest to the metering cover usually a chrome cover held with four screws, the other conection on the carb goes to the suction side of the primer bulb, normally the shorter of the two conections, the pressure side of the primer goes back to the tank, this pipe just sits in the tank to act as a return, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
Jul 23, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
Poulan hedge trimmer GHT 225 it is a dash 2 How to adjust needle valves after replacing fuel lines (they are on the correct sides) the switch wires aren't pinched or broken and fuel seems to flow when...
The small green rubber thing sounds like the duckbill vent for a gas cap. Since the gas cap vent sits right over the open hole of the tank, I would check the underside of the gas cap. See if the little rubber vent is there. Normally, they will use a small clear nylon connector to hold the return line inside the tank. The small green thing sure sounds like a fuel cap vent. Here is a link to the diaphragm carburetors site with a tutorial on tuning these little carburetors. I will give you one from Zama and one from Walbro....Zama first.
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
Jun 08, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 22, 2010 | Poulan 14" Chainsaw
What is the breakin period for a poulan 1950
I would say a full tank of fuel, but there really is not any " break in" time stated in maual.
Feb 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to replace all of the gas lines. Do I have
There is no reason to disassemble your saw, Please stop.
You can find a typical fuel system and a couple of suggestions here:
An IPL for a Poulan “PP3816 Gas Saw Type 2” can be found here - There are slightly different models. Please ensure this applies to your saw:
http://www.ordertree.com/modelinfo/PWE/PP3816-Gas-Saw-Type-2/75.PP3816-Gas-Saw-Type-2.1.59.1.html
The small hose goes between the filter and carburetor and from the IPL the carburetor and primer.
The large hose between the primer and fuel tank (return).
If the above is not the correct model it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Hose can be purchased at any chainsaw outlet, Inquire about how much hose they recommend. I have not found a good hose stretcher and I have been looking. Good luck with your project. Any additional questions you may have can be asked below. I hope you found this most helpful.
Lou
Jan 31, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I wish someone out there could draw me a diagram of how the gas line are supposed to be routed on poulan pro 210 chainsaw
An IPL for a Poulan PP210 can be found here:
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
Lou
Jan 29, 2010 | Poulan Garden
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
Electrical Supplies Logo
138 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
