Optimus cd 6500 scrolls "m-error" (memory error) - have tried turning it off and unplugging it a number of times
  • sunburst586 Dec 16, 2008
    M-ERROR comes across the screen. Every lights up and appears to be working. As soon as you press the play button the m-error shows, at that time you have to turn off. There is no buttons that will work. I have turned power off and on and have also un plugged. Help.. I have had this unit since it was new.
    Although it is 12 yr old.. I have never had a problem.
4 Suggested Answers
  • 3230 Answers
SOURCE: error code 6500 flashing
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Posted on Oct 01, 2009
cene765
  • 787 Answers
SOURCE: canon error code 6500
It's a hardware error.Your printer need service.
Posted on Oct 08, 2009
  • 1044 Answers
SOURCE: i have a HP Officejet
Please go to the following link and your problem will be solved.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&dlc=en&lc=en&product=3795406&tmp_track_link=ot_search#N53
Posted on Aug 22, 2011
My HP Officejet 6500 Wireless just started printing a blank page and bringing up the error message "Paper Mismatch' - been using this for over a year with no probloems
1. Unplug the power cord from the back of the printer. 2. Press and hold the # key and the number 6 and plug the printer back in all at the same time. 3. Release the keys once the printer is already turned on.
If the printer takes the paper but only crumples it. Do the Reset for the 2nd time.
Feb 03, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP fax 6500 is sending fax but is not receiving fax
There could be several reasons for it. the basic one is..
Press SETUP Button on front panel
Scroll to Fax setting or Advanced Fax settings - Press OK
Check for Error Correction Mode or ECM - Press OK
Turn the ECM Off - Press OK
Try to receive fax.
Oct 29, 2010 | HP Officejet 6500 Wireless All-in-One...
Turn on and error 6500 displays? How to fix?
The Service Manual for the MP500, which is very close to the MP450, indicates that the error code of 6500 is a PCI buss error and this is a Service Error Code. Typically this is an internal error of one of the ASCI chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
If you want to take the time to try and repair it, you can take the unit apart and search for a loose connection, or unplug and replug all connections. Other than that, you can sell it for parts.
Good luck
Aug 11, 2010 | Canon Pixma MP450 All-In-One InkJet...
Code Required for Visteon 6500 Europe -------------------------------------------------------------------------------- Hi please could someone help me out I am trying to obtain a Key code for my Landrover...
Go to carhelpsite.com it is free as long as you click on 2 of the ads at the website then your questions will be answered by an ASE certified mechanic,you don't have to buy or fill out anything on the ads,so help keep the site free.
Apr 14, 2010 | 2003 Land Rover Freelander
Canon MP830 error 6500
Error 6500 is a logic board error code (= 'other hardware error').
Before committing to replacing a logic board, ensure that the error has not been generated and held by spurious external signals. Reseat the ink cartridges. Remove any memory card(s). Check any flaps / covers are properly closed (eg. CD printing cover). Turn off the printer and disconnect the power lead and USB lead to the computer. Leave the printer disconnected from power and data signals for several minutes, allowing time for any static electrical signals present on the logic board to discharge.
Reconnect printer and test.
Feb 25, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Canon error code 6500
The PCI bus error is detected by the ASIC. - Logic board problem
Oct 08, 2009 | Canon Office Equipment & Supplies
Error code 6500 flashing
4. Properly seated
Good Luck!!
Thanks
May 03, 2009 | Canon Office Equipment & Supplies
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
6500 slide
for new nokia phone you have to go nokia service center or Mobile Phone Service shop to unlock it. Their still no free solution at this time.
Jun 24, 2008 | Nokia 6600
114 people viewed this question
 Grubhead
Grubhead
