Question about Dishwashers
Indesit idl530 error code
I have an error code of 1 flashing light the prewash one can you tell me what that means
Go to indesitservice.co.uk and look at he online manual for the machine. it tels you what it ean in there
Posted on Oct 09, 2008
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
My Indesit idl 530 dishwash which is fairly new has packed up with the Prewash and Drying light flashing simultaneously. I know it's under warranty but I'm trying to find out what this error code means and...
Refer the user guide for the error meaning. Switch off the machine and try.
Still the same problem contact the service engineer as this will ease your work!
May 17, 2010 | Dishwashers
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit idl530 2nd and 4th lights flashing
rang indesit enginners there is a fault with the heating element needs to be replaced thankfully under guarantee only had it 8 weeks 13.08.09
Sep 23, 2008 | Indesit Dishwashers
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
The second two lights on my dishwasher are flashing and not working any help would be great IDL530
On my IDL40S the second two lights showed that the water was not getting through. Have you checked the supply?
Jul 20, 2008 | Indesit Dishwashers
Indesit idl530 2 flashing lights
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
Jun 13, 2008 | Indesit 24 in. D63 Free-standing...
Indesit IDL 530 Dishwasher Prewash and Drying Light flashing
Ours was doing this and it was because there was water leaking into the base because a crocodile clip had come off
Oct 22, 2007 | Dishwashers
Dishwashers Logo
608 people viewed this question
Top Dishwashers Experts
