Question about Pioneer Audio Players & Recorders
Pioneer dc-z93 amp and tape deck,one tape deck wont work at all the other keeps stopping,any ideas on what it could be?
  • 752 Answers
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Posted on Oct 13, 2007
SOURCE: DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Posted on May 13, 2008
SOURCE: CT-W602R Dual Cassette Deck- door won't open
had same problem, just changed the belts and works like new.
Posted on Nov 18, 2008
  • 1170 Answers
SOURCE: Hi, My Pioneer CTF-7272 Cassette Deck has stopped
check the belt whether it is broken or loose. if so replace the belt.
I hope this will solve your issue.
Good luck
If my solution proves useful please rank it.
Posted on Mar 27, 2009
  • 54 Answers
SOURCE: Forward switch wont work on one deck and the fast
Yes, you can repair this problem, you have to change micro switch on both decks
Dj Ajay
Posted on Jun 11, 2010
Testimonial: "Thanks Ajay! Please advise some more. Where is the micro switch located (or what does it look like) and where can I purchase it?"
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Tuner problems
If you can hear music from other sources then it likely that it's the tuner that has the fault. Most tuners these days are one or two IC's. I would suspect them in this case. You can find them easily as there will lots of coils around them.
Feb 19, 2014 | Pioneer Audio Players & Recorders
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Pioneer pl z93
You can find these cheaply. Will need at least 1 amp, but no harm giving it 2 or more. Maybe you can locate the motor's information
Dec 10, 2013 | Audio Players & Recorders
Pioneer Cassette Deck Repair
Anything that eats tapes means the take-up torque is low of stopping due to bad belts or a bad Idler system or even cracked tires. The transport have to be taken out and those parts replaced and then it will work again.
Feb 05, 2012 | Pioneer Audio Players & Recorders
How can i use a pioneer PL-Z93 turntable with a pioneer A-717 amp?
Hi, there is no reason for the turntable not to work with your amp. This amp has 2 phono inputs. Moving magnet and moving coil. Your tt likely has a moving magnet cartridge fitted so connect via that input. Cheers John.
Nov 14, 2011 | Audio Players & Recorders
PIONEER CT 670 user manual ,in need,thanx a lott
You can try to download the manual from the following site.
I am not sure how big it is, but you can at least look at it if you don't want to print it out.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
Feb 08, 2010 | Pioneer Audio Players & Recorders
Hi, My Pioneer CTF-7272 Cassette Deck has stopped playing. Rewind works fine, but FF and Play will run for about 5 seconds and then the tape just stops. Any info on this problem is greaty appreciated....
Good luck
Mar 27, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
653 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
