Question about Canon PIXMA MP750 All-In-One InkJet Printer
Document print quality
I love my printer and it has always provided good quality printin, especially for resumes. Lately though I keep getting a line through the print. It's always in the same place and goes horizotally across the entire document. Any suggestions how I can fix this?
  • 4 Answers
A solid line sounds like a jet (in the print head) always on. Replace the print head (<$50 on eBay).
A white line (no ink) sounds like a clogged print head or a burned out jet. Replacing the print head will fix either one. If it is clogged, you might be able to clean it but this procedure is complex (soaking or special cleaners). Read about cleaning in other posts.
Posted on Sep 01, 2008
Black shadow line appears on printed documents. Tried to clean but still appears
Print quality issues of this type are almost always coming from the toner cartridge. Try swapping out the cartridge. Even with a used one just as a test to see if the line goes away. 90% or better chance that changing the toner cartridge will fix this.
Good Luck
Dec 30, 2009 | HP LaserJet 2100 Printer
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Xerox Phaser 4510 laser Printing Quality
Hy, this problem is caused because the print cartridge is out of range. try changing with other cartridge from the other machinne. or buy another cartridge
Jul 17, 2009 | Xerox Phaser 4500 Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printin Problem
Call Kodak for a new printhead. The printheads go bad.
Dec 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
On cleaning the pads of canon printer
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
Aug 19, 2008 | Canon BJC 3000 InkJet Printer
'Speckled' Printing
Do you have the owners manual? Did you cancel the document from the computer and turn the printer off for at least 30 secs. The speckled print and lines are usually caused by a defective toner or worn drum. Usually a drum will last for 10 thousand or more cycles. But sometimes prematurely wear out. Make sure you are absolutely using a genuine Brother OEM supply. Generics have a high failure rate. This is not a heavy duty printer. When you need a drum and toner together, it will be just as cheap to buy another low end Brother printer.
Mar 30, 2007 | Brother HL-2040 Laser Printer
Canon PIXMA MP750 All-In-One InkJet Printer Logo
70 people viewed this question
old marine
old marine
