SOURCE: 1993 mazda 626: could not get trans out of park!
Ignition lock is activated: You over rode it but still have original problem. Alarm system might be confused. SO....
1 disconnect battery negative (-) cable(make you have radio code if any) to reactivate radio, which works anyway if code was never set.
2 press brake peddle for 5 seconds
3 reconnect negative cable to battery.
use key and twist diver door lock to OPEN (this resets alarm which might have caused ignition lock module to activate.
You should be able to turn on the ignition, start the engine and shift out of park. Hope this helps.
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
SOURCE: spark plug wire diagram position from distributor
For the 1996 Mazda 626 2.0L DOHC In-Line 4-Cylinder:
Firing Order:
1 - 3 - 4 - 2
Cylinders:
.........(back).........
|..1....2....3....4...|
........(front)
Distributor:
__________
/////////////////| <---2
_______________
//////////////////////////| <------1
___________
///////////////////| <----C
_______________
//////////////////////////| <-------3
__________
/////////////////| <----4
Let me know if this helped and thanks for using Fixya!
