Question about IBM ThinkPad T40 2373 Notebook
Laptop Turning On But Nothing Happens - Replaced Memory
My laptop turns on, fan runs but nothing happens. I switched the RAM memory chip on the top with the one on the bottom (and left the bottom memory slot empty). It started up but then froze. Turned off, then back on and went into bios settings, but it froze again. Turned off, then back on, and it started doing the same thing again where laptop turns on, fan turns on, but nothing happens.
Anybody run into the same problem? There must be something in the top memory slot causing the memory to short out. I ordered more memory, but am reluctant to put it in, because I don't want to ruin more memory. My next step I'm considering taking is ordering a new motherboard. This is an old computer so I don't want to sink a lot of money into it, but it does still get used daily.
Thanks.
  • 1 more comment
  • goose123 Jul 30, 2008
    Maybe I should have been clearer. My laptop initially exhibited this problem with both memory chips installed. I took out the bottom chip only and the problem still existed, so I took out the top chip and replaced it with the chip from the bottom. It worked initially, but then the computer froze up several times and finally the same laptop on, fan running but nothing happens problem started again after I turned the computer off and back on again after it froze the last time. This is what makes me think something is frying the chips...because I tried both chips individually, and when I tried the second, it initially worked.
    Any ideas? Thanks.
  • gecsdad Aug 11, 2008
    I have what sounds like the same problem and noticed that when mine attemps to start up, the fan comes on but I get no video and the system does not try to access the hard drive.
    From what I have read, I am trying to determine if the issue is with the video chip as described in other postings, a memory problem or something else.
    Does anyone know the boot up sequence/ requirements for the T40 Thinkpad?
  • mowaffa Jan 16, 2009
    I have an acer laptop aspire 1350. I removed the memory ram the other day and placed it back again. Now, I don't have any power in my laptop, just light flashes for a fraction of a second and nothing else happens. Any ideas please!!!
    moofy
    Genius:
  • 2,028 Answers
This does sound like a memory problem, and it more likely that a memory chip is bad versus the memory slot. The slots will be numbered 1&2, the memory will generally work in either, but the 1 slot is preferred. Try starting with just one chip in, try both slots, then try the other chip. It may just be one chip that is bad. If it is the slot, it shouldn't hurt the chip, but the motherboard will need replaced in order to fix it.
Posted on Jul 30, 2008
Laptop won't turn on
is it bleeping at you?if so check the ram and check the fan is running to make sure she is not getting hot.
Apr 22, 2014 | Samsung Laptop / Intel Core i7 Processor /...
My laptop turns on but has black screen. power plug light comes on and the power on light comes on but nothing else. the hdd light does not come on or blink, flas or anything. the hdd sounds like it is...
if turning it on with no RAM installed doesn't make it beep to indicate no RAM, it's sounding like it is the motherboard that is damaged.
If the computer is still under warranty, I'd suggest taking advantage of that warranty to have the motherboard replaced. If not, you are better off just buying a new computer.
Oct 10, 2013 | Toshiba Satellite L455D-S5976 Notebook
My Acer Laptop model is Aspire 4920 and when I switch it on, I hear 3 beep sounds and nothing happens on the screen. The power stays on and nothing happens. Please advise what do to to get it back to...
Hi Friend, The 3 beep codes indicates that the issue is with the RAM (memory) of the system, so i would recommend you to please open the laptop and try to locate the RAM on the system and reseat them (unplug and plug them back in) Try to turn on the system and check if the issue is fixed.
Please let me know if it was of some help
Thank you,
Jan 06, 2011 | Acer (9005210464), (64 MB) Graphic Card
When turning the laptop on, it's not booting up. The screen is black and the green light stays solid, though I can hear the fan.
First thing you should try is:
reseat the memory chips (try booting just one single chip in one slot, if that doesn't work switch the module to the other slot)
Also I'd recommend booting without battery pack installed.
Let me know what happens or if anything changes with the above.
Aug 14, 2010 | Acer Aspire 5100 Notebook
When I power on my laptop there's a beep code, on my m30x-s181st
That is your memory error code.
Re-seat your ram, or restore the ram you replaced it with if this is an upgrade. If neither of those apply, you should test your ram slots by leaving your ram door opened and apply constant pressure with your fingers lightly pushing the ram stick while booting.
If you get a boot screen, then you have the infamous goal post flex.
Those little upright locking wings on each side of your ram will flex over time and allow the memory stick to float up, unseating your ram.
Those little plastic brackets holding your locks on just get tired and begin stretching and relaxing over time
When this happens, your ram LOOKS like it is seated, but it's actually floating away from the contacts. I have fixed many Dell Laptops with this problem by placing hard packing foam under the ram door to keep the memory sticks seated. Yes it's cheap, but it's also permanent.
Apr 08, 2010 | Toshiba Satellite M30X-S181ST Laptop
Upon turning on my comouter i hear two beeps and then it goes to a gray/black screen that gives me two options "press F1 to resume , F2 to setup. I have pressed both and nothing happens
This a memory parity error.
It is telling you your memory is bad. Try replacing the first stick of RAM and try to boot again.
If your computer has built-in memory, it means a new motheboard.
Sep 25, 2009 | HP Compaq Presario V2000 Notebook
Compaq laptop won't turn on
Take out the battery completely and only hook up the adaptor and see if it turns on then. If it turns on then your battery is bad. If you try both adaptors and get the same flashing lights then the motherboard is bad.
Feb 04, 2009 | HP 435768-001 - Compaq Presario C300...
Problem installing ram
You have the wrong memory chip. The beep code you hear indicates that there is no memory or incompatible memory. The memory you need is PC4200, Which is a 533mhz chip. Memory has a frequency rating that is matched to the processor and motherboard. Not just any DDR 200 pin memory that fits will work, the frequency has to match or it won't work. The new chip should be labeled, make sure it reads PC4200 or 533mhz, if it reads anything else it's the wrong chip. If it is the right frequency chip, then you may have a bad memory slot, the chip is bad, or mislabeled. Here's a link to a memory configurator that gives the memory specs for your machine.
http://patriotmem.com/configurator/modelp.jsp
Jul 31, 2008 | IBM ThinkPad R52 Notebook
Laptop Turning On But Nothing Happens - Replaced...
I see, now before you rate me, (cause I like my rateing lol) can you get to the bios? And if so, does this machine have a hard drive diagnostics test?
Jul 30, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
1,586 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
