Question about Toshiba Satellite A70 Notebook
AC wire connection may have problem
When AC wire is connected and when the laptop is not start up yet, the light for the wire connection is on (green light), and also the light for the battery is also on (red light). Once I press on button to start up the laptop, then the light for the battery is off. When the system is fully started, I check the AC power source and it is on battery instead of on AC power. The battery drain really fast. Within 15 minutes, it could drain from 90 % to 60%.
Is the AC power cord not functioning ? Or the battery is weak ? Or any other issue ?
  • Anonymous Mar 18, 2014
    Installed fog lights,connected existing wires at lights,15 amp fuse and relay in fuse/relay box- turned light switch on colum- no light happens
  • 125 Answers
Try this remove the battery and plug it in to the power supply and turn it on if everything works fine its the battery if not its the charger which you'll need a new one
Posted on Jul 27, 2009
Toyota tundra ac light switch keeps blinking
Wrong category Roger. Anyway I have read on a toyota forum that the ground wire on the AC compressor may cause this type of flashing green light of death. It was suggested the ground wire connection may be loose and the screw holding it may need to be tightened.
If your AC light is blinking check this first Toyota Nation Forum...
Jun 12, 2014 | Computers & Internet
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
My Dell Inspiron 1525 has no power. Tried a different ac adapter, no help. Reseated the battery, hard drive and memory and still no power. Computer will not start.
Make sure that there is a green light on the ac adapter. Try checking the end of the cable of the ac adapter and see if it is damaged ( the metal piece that connects into the laptop ). Also check the port on the laptop where you connect the cable of the ac adapter. If that is damaged then you have to request replacment of the motherboard if your laptop is still in warranty.
Nov 22, 2010 | Dell Inspiron 1525 Notebook
I need a diagram for the wiring that goes from the fan to remote speed settings and then to electrical wires in ceiling
all of the white wires connect together and to the white house wiring (neutral from ceiling) ..also the neutral or return wire for the controller (may also be white) .. then the black house wiring(or red if you have an external wall switch) is connected to the controller wire marked AC or AC input .. the output marked "lamp" on the controller connects to the blue wire that goes to the light bulb (or bulbs) ... the output called fan goes to the black wire of the fan motor .. the green house wire goes to either a bare wire, green wire or a green bolt that is screwed to the metal of the fan.. thats the safety ground ...
Jun 05, 2010 | Hunter 52" Ceiling Fan With Light And...
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Jan 06, 2010 | Goodman Heating & Cooling
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
Toshiba Satellite A70 Notebook Logo
175 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
