Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I need to replace a battery in the Black & Decker CMM1000 cordless lawn mover but I can't find any directions. Can someone help me?
The battery in my CMM1000, purchased in 2003, finally gave up early in the summer of 2009. I bought a replacement battery at the local DeWalt store for about $140 including tax. The original battery was comprised of two Panasonic 12Volt, 20Amp-hour units in series. The replacement battery is comprised of two BR 12Volt, 17Amp-hour batteries in series. To replace the battery, simply remove two Torx screws toward the front on top of the black cover and two more, one on each side of the cover down next to the orange base toward the rear. It is not necessary to remove the two screws near the charge indicating meter. Cut the first two or three tiewraps holding the "throttle" cable to the push handle so as provide some slack. Lift the black cover up and over the height adjusting handle. Do that and everything else to be described here while working from the opposite side of the machine. The cover will not come all the way off and it is not necessary for it to do so. It will lift up far enough to allow removal of two pieces of styrofoam, one between the battery and the motor, the other between the battery and the inside rear of the housing, and the battery. The battery is held down by a fabric strap that is attached to the base of the machine with a screw on each side. Remove the one opposite the height adjuster. The battery will then be "loose" except for the two electrical wires that connect it to the machine. Lift and rotate the battery so as to present easy access to the terminals. I used my B&D drill motor with the appropriate socket to remove the flanged nuts retaining the cables. The battery can be removed from the machine once the cables are disconnected. Reverse the above procedures to install the new battery. Important note: The throttle cable has to go under the front styrofoam piece... the black cover will not go all the way down until the cable is in the right place. One might be tempted to push harder and that could lead to real trouble, so be sure the cable is under the styrofoam. The CMM1000 is an excellent machine in my opinion, and the ton or so that it weighs provides a good workout for me that I personally enjoy.
Posted on Aug 21, 2009
I followed fixyourself's directions on my 6 year old CMM1000 with great success and just wanted to add the only tools needed were a T20 X 3 torque screwdriver plus a small monkey wrench to remove the nuts. My mower only had one piece of styrofoam behind the battery, so the process was simpler for me.
Posted on Aug 22, 2009
    Champion:
  • 313 Answers
There's a recall for this unit for convertion to cmm1200. if are where you let the service center do the job of replacing the battery & pay for it at the same time they will convert the unit to CMM1200 for free/recall. see wwwblackanddecker.com
Posted on Aug 01, 2008
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
Battery to fit Black & Decker CST20000 Grasshog weed eater. Where can I buy just the battery or battery pack?
Unfortunately, the battery pack as a unit has been discontinued, but the battery itself (part #243213-00) can be purchased online. Amazon sells it for $35.99. You can find it here:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
May 20, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Short battery charge
The B & D MM575 mower is not battery operated nor is it cordless. CMM1200 CMM1936 CMM1836 are the currently available cordless mowers. You can buy a battery from B &D, they list it here:
http://blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=22989
tom
May 10, 2010 | Black & Decker Black and Decker Mm575 18"...
Black & Decker CMM1000: The mower runs, but has no power
The battery is dying., need to be replaced. price is around $100.00 so be prepared to invest a couple of bucks. I believe there is an update "RECALL" on this units so you better call their customer service.
Sep 20, 2009 | Black & Decker Garden
Black & Decker CMM1000 Cordless Mulcing Mower Won't Start
The gauge is only active when the mower is running! (See page 6 of the INSTRUCTION MANUAL)
Sep 12, 2009 | Black & Decker 19" Electric Lawnhog...
I need the large cordless battery for the black and decker cordless mower, and also need the power charging board in the mower.
the largest is the 24v CMM1000. now the circuit board for the said model are hard to get. but upgrade are available & convert it to CMM1200 model. convertion kit includes instruction how to, a wiring assy & a charger.
Jul 03, 2008 | Black & Decker 19" Electric Lawnhog...
Replacement batterys for cmm1200 black&decker electric mower
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
386 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
