Step 1 - Open the Case
Use a small screwdriver to open the case. Be careful with the contents inside after the case is open, as you do not want the tape and the system to fall out of the case and unwind. To prevent this, keep your finger on top or use a small piece of masking tape to keep everything in place.
Step 2 - Look Inside
Take a look inside the case to see if there is a simple problem with the retraction system. For example, the spring might be undamaged but unhinged from the tape, or there might be dirt clogging the spring. If it's an easy fix, remove the dirt or reinsert the spring, and then proceed to the sixth step to close the case.
Step 3 - Remove the Tape
If the problem runs deeper than a bit of debris, you will have to remove the tape to observe the retraction system. Take the tape slowly out of the case, holding the retraction system in place. Once the tape is completely out, disconnect it from the spring.
Step 4 - Replace or Fix the Retraction System
If the spring is broken, disconnected, or damaged, you will need to replace it with a new one. You can purchase a new part at the same store you bought your tape measure from. Make sure you have the model number and size when you go to the store to get the exact fit.
Step 5 - Put the Tape Back
After replacing the spring, connect the tape to the spring by putting the end of the spring into the hole at the start of the tape. There is usually a part connected with tape. Use some masking tape to put it back together. After you've secured the connection, let the tape roll slowly back into the case.
Step 6 - Close the Case
Having tested the retraction system by letting the tape roll in, you have successfully repaired your retraction system. Now, remove the masking tape keeping the system inside the case, and reattach the top cover with the screwdriver. Your measuring tape should retract again properly.
If, after completing this guide, your tape measure still doesn't work properly, consider purchasing a new one or
upgrading to a laser tape measure for reading at a distance.
