Printer card transfer monitor has a problem When I try to print, the page feeds into the printer and then stops. The computer pops up a message 'printer card transfer monitor has encountered a problem and must shut down'. I did install a new Lexmark printer. It was just like the previous unit.
  • Anonymous Mar 13, 2014
    message on start up printer card transfer monitor has stopped working
  • 6,487 Answers
Make sure that you are using the correct printer driver because windows operating system can install a generic driver for printers..
Hope that helps.....
Posted on Jul 30, 2008
    Genius:
  • 3,422 Answers
Did you make sure the Software supports the operating sytem you are using?I mean if your operating system is vista the software will not work if it supports only xp.
  • Priya darshan Jul 30, 2008
    Also please run any registry cleaner program to clean the registry and fix any errors.
  • 13,433 Answers
Seems to be a issue with the software, Best to update it to the newest version.
Brand and model of your printer? lexmark and?
Posted on Aug 20, 2008
Canon LBP6000. Data transfer to the printer timed out, or a transfer error has occurred. Click [Resolve Error] to resume printing, or click [Cancel] after pausing the job, then try to print again.
Best to un-install the printer drivers, softwares related to this printer. Go to Canon.com and download the latest drivers and software. Connect the printer to the computer and let the computer recognise it and then install the drivers from your download. You can also check if there is any damage to the cable as this could also stop the communication between the computer and printer.
Dec 09, 2013 | Canon LBP6000 Laser Printer
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
While copying on 4215 HP officejet printer, it has stopped
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 22, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP 5610v states 'paper jam' and there isn't one - how to reset?
Jan 08, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer card transfer monitor problem..can you help me with this?
I had the same problem with my lexmark x4850 printer it just kept poping up I uninstalled the software and reinstalled it, it was doing the same thing. I just repaired my Microsoft Netframe 2.0 and it has gone away.
helpful hand
Dec 30, 2008 | Lexmark X2600 InkJet Printer
Displayed fault is 'Paper Jam'
you amy need to reset your printer let me no if you need the info on how to reset your printer
Sep 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Samsung clp 510
usually happens when the NIC card goes bad, may need to replace.
first try resetting the printer, look in your manual
Aug 25, 2008 | Samsung CLP-510 Laser Printer
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Adjusting printheads - won't stop and keeps printing blank pages
Hi Did you have any print jobs sent to the printer before replacing the printhead. It seems that the printer is trying to print a job and since the usb cable has been disconnected and reconnected the printer is printing blank pages or misc text.
Dec 03, 2007 | HP Officejet 9110 All-In-One InkJet...
Will not feed paper
There could be a small piece of paper or other matter blocking the feed. Try feeding a piece of thin card- simple load and eject don't try to print anything. Or Put a vacuum nozzle in the slot to suck any debris out. Come back for more advice if this is not the answer.
May 08, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
