Question about SanDisk Sansa e250 MP3 Player
SANSA E250 Actually i the problem started when i tried to install new firmware.I actually by mistake pasted a file on the device which was possibly corrupted.After that my sansa e250 won't connect to the PC and when turned on the blue light only bulbs up.I have know way to fix it.I hope you will definetly fix it. Please help, regards srijan
  • 2 more comments
  • srijan Jul 31, 2008
    well installing firmware is of no use as the player won't connect to the PC.However i am able to connect the player partially.When in plug in the usb and hold the select button a hardware is found but it doesn't install.
    please let me know how to format the deviece by itself because its not even opening so how can i format it.
    yes
    Actually i live in india and my uncle gave it from USA.So no use of calling.I have found something on a forum check it and ADVICE please.http://www.anythingbutipod.com/forum/sho...[link]
  • 758 Answers
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Jul 31, 2008
  • 1 more comment
  • Jean Sintulaire Jul 31, 2008
    Have you tried to format the device using the device itself? if not go under menu, settings, format...let me know what the outcome is...
    Your device doesnt turn on at all?
    Call sandisk to see if they are willing to set up an RMA for you...you can try changing the battery...
I can't update my sansa e250 mp-player
Does just going into computer right click drive and then quick format help. Not positive on that one.
Nov 13, 2009 | SanDisk Sansa e250 MP3 Player
Regarding video
You must use the Sansa Media Converter to transfer videos. If the video is DRM-protected (many of Real's movies are), it may not actually convert. But if the video is DRM-free, then the Sansa Media Converter will perform the conversion and load the video onto the player. The Sansa Media Converter may or may not recognize certain file formats, so you may need to download an additional program such as Riva FLV Encoder to convert the Real video to AVI format first - then the Sansa Media Converter will recognize the file.
-Tha Mp3 Doctor
Feb 18, 2009 | SanDisk Sansa e250 MP3 Player
All the music files seems to be deleted, Sansa e250 isn't resetting,..
Try the other recovery methods - a firmware upgrade MIGHT restore the player's native software.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 14, 2008 | SanDisk Sansa e250 MP3 Player
ITunes and E250
if you install the media converter that came with it then i believe so
Jan 29, 2008 | SanDisk Sansa e250 MP3 Player
Unable to recover my sansa
i guess you will have to reinstall the hole mp4
Jan 18, 2008 | SanDisk Sansa e250 MP3 Player
My Sandisk Sansa e250r keeps freezing up....
I called sansa and got this info on how to format the sansa and restore it back to default
This helped me to detect the device and be able to put songs on it.
Turn off device
put hold key on
press and hold mic key while pluggin in the device to pc
open sansa icon in my computer
Up on top of my computer window click tools then folder options and click view tab then uncheck hide extension for known file types.
Now click file new and choose text document then change the name from New Text Document.txt to sansa.fmt and click enter. It will ask you if you want to change the extention and you need to click yes.
Now unplug your sansa from the pc and this will format your whole mp3 player.
You will lose all your date but your sansa will be detected and working.
Once it is done then turn off your device and plug it in while its off.
It should show up in my documents now. The first drive is your hd on the device and the second one is for the extra micro disk.
Oh and another tip is to click show hidden files so that you can see the music folder.
This way you can just drag and drop without having to use windows media player or Rhapsody.
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 firmware problem
Verify that the device DOES NOT say RHAPSODY on the back or E2**R. This would indicate the rhapsody version, whereas the firmware is totally different.
If it is simply a E200, try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 28, 2007 | SanDisk Sansa e250 MP3 Player
Not showing video
Try This;
Best of Luck.
Nov 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E250- Only the blue light comes on? HELP????????????
Try this: Switch your Sansa e250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the e250 LCD screen displays "Welcome to Recovery Mode" (if the LCD remains black, keep pressing long enough -- about 10 seconds -- then proceed to the next step) 5. Connect your e250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa e250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the e250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa e250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... or use this Sansa Firmware Updater link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player (or find the most updated firmware) and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your e250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your e250 and 90-99% of the time, it would boot up successfully. I hope this helps.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
My e250 wont let me add or delete any files
-Tha Mp3 Doctor
Dec 30, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
