Every now and a gain a white horozontial line will flash for a split second on my lcd tv.It is a samsung le40m86bdx/xeu. happens watching sky hd. Ps3.
  • Anonymous May 12, 2009
    A thin horitonzal white line flashes every once a while. Sony Bravia W4500 + PS3.
5 Suggested Answers
  • 279 Answers
SOURCE: sony kdf-e50a12u rear projection lcd bravia. red shadows
This *CAN* be fixed. This TV has a problem with running in the 60 Hz range with default factory settings, but it can be adjusted to remove the shadows. Be careful, though, the wrong setting in the service menu can really mess up a TV. Here's how you do it: To bring up the "service" menu, put the TV in standby mode, then press in sequence : Onscreen Display ( the little screen with the i+ in it ) 5 ( channel number 5 ) Volume Up ( upper end of volume button ) Analogue ( middle top button ) The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it. Press the "menu" button ( middle bottom ) Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu. Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust ) Move down to "S H Pos Reg G". It should be "10", change it to "11". Move down to "SHPos Reg B". It should be "10", change it to "11". Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Posted on Sep 21, 2007
SOURCE: Sony kdf-e50a12u rear projection lcd bravia. red...shadows
try this http://www.avforums.com/forums/showthread.php?t=459681
Posted on Oct 02, 2007
SOURCE: Samsung LE32R7 Picture Flashing
I have a 37"Samsung LCD and having just spoken to the Sky engineer (also a friend) he says it is a national problem between Sky+ and Samsung. I have the same problem when on playback but not on real time? If you had your box changed to an Amstrad what sort did you have the problem with?
Posted on Apr 21, 2008
jissa
  • 13 Answers
SOURCE: Samsung LE52M8 fault, there is
i need model number to give the solution
Posted on May 12, 2008
Samsung le40f71bx picture flickers on and off with hd source
I've had similar for a long time, now the picture only lasts a few minutes or seconds. Have to turn the TV off, wait 5 minutes, turn it back on. That's with Sky HD. Used to be the same with SCART but I don't use that any more, and I get it with the Wii on Component. However HD DVD and Blu Ray players are no problem!
See my post here - http://www.avforums.com/forums/lcd-led-lcd-tvs/1622157-samsung-f71-flashing-pattern-fault.html
Way out of warranty but really just need some repair expert to tell me what needs fixing. Taking the cover off there are very few components and look easy to replace, and seen some on ebay. A fix from Samsung would be vastly in excess of the value of the TV.
Apr 21, 2012 | Video Game Consoles & Games
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
My samsung tv LE32S73BDX/XEU will not turn on red power on light continually flashes any suggestions please
sounds like the power supply board has failed and should be replaced. most common problem for all samsungs.
Oct 26, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Jun 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Picture Flashing
I have a similar problem but my picture flashes black and white and the sound goes at the same. Also sometimes it will flash pink and blue. I've read elsewhere that the issue is a known problem with compatability between Samsung tv's and sky boxes. Apparently the box needs to be replaced but I'm unsure what type of box. I've read perhaps a PACE sky box could fix the problem. I think the best option would be to contact Samsung - that's what I'm going to do.
Feb 14, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
You need to get your sky box changed! just ring them up and tell them your problem. the TV is a known issue with certain boxes.
Feb 14, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
