Question about PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres
Scanning array... forever
I got this motheboard from tigerdirect.com, I can run the bios program, and it seems to see all of my hardware installed. (it was a package deal with 2GB ddr2 memory and an ata hard drive, I also got windows vista home and a nvidia 8500 video card) I also got windows vista, but I can't install it because after the initial disgnostic screen, (where it says pres delete for bios, f11 for boot menu) the screen clears and a new screen says nvidia bios, then scanning array... and hangs right there. I have cleared the cmos and reset but it always gets to here and freezes.
  • 1 more comment
  • moonyeti Jul 30, 2008
    no beep codes, I'm pretty sure the memory is correct and the power supply, as they were a package deal from tigerdirect. also, I could turn the memory diagnostic on in bios, and it counted up the memory. The screen it hangs on is the next screen after the 1st bios screen.
    thanks
  • moonyeti Jul 31, 2008
    Ok I figured it out.. I was shutting off the on board graphics card so the one I installed could then take over. However I did not realise that shutting this off also affected the on board lan for some reason. So I had to go into BIOS, ENABLE the lan, but DISABLE the lan on boot (or something similar it was called).
    I then restarted and poof! working computer. Vista then installed and I was good to go. Thanks for the suggestions!
  • Styme
    Styme May 11, 2010
    You have any type of beep code ?
    Possitive the memory will work with that motherboard ?
    Power supply strong enough to boot the motherboard and video card ?
  • 781 Answers
Is your BIOS set to boot from cd if it is not you have nothing on computer for it to do
Posted on Jul 30, 2008
How do you fix a corrupted bios?
I don't think it's corrupt bios, maybe a virus or malware.
But if you can go to the computers maker website and download bios and install them the way they tell you to install them.
Feb 01, 2016 | Computers & Internet
I want to upgrade my WiFi card to a N (300bps) one and bought a 512AN_MMW; however that is not supported by my notebook (msg 104). What to do?
My suggestion would be remove the 512AN_MMW, then update the BIOS.
The latest BIOS is 20, once you update the BIOS install the 512AN and see if it solves the issue.
Feb 14, 2013 | Computers & Internet
I am trying to install SBS 2011 (Win Server 2008 R2 OS) on an IBM x3400. I have created a Raid 1 (mirrored) array. When partitioning the RAID to install we get the message "Windows cannot be installed...
A few questions:
1. Is this a new (clean) install? If so, have you installed the drivers for the RAID controller BEFORE you install the os? Most of the time Windows will ask for this as the os check your sysem. (You will see at the bottom of the screen "if you have a 3rd party controller and need to install drivers, do so now" or something to this effect.
2. If you already have an os on this system, (Server 2008) you may need to check the the HCL for SBS 2011 to make sure you hardware is correct for the install.
Good Luck
C2Solutions
Aug 11, 2011 | IBM x3400 Server
I upgraded matheboard from p6t6 (stopped working for some reazon) to p6t7. My hard drives have been set up to raid. I have windows 7 ultimate installed. I set bios to raid and choose proper disc as boot 1...
On many systems with RAID1 support built into the mobo chipset, that system includes some RAID management software in BIOS. You won't see it until you turn on RAID capabilities in the BIOS and add a drive. But you might find all the details you need in manuals on the matter from Dell, so look for those. They could have come with your machine, or you may have to search their website and download.
On systems I've seen you create and manage RAID arrays using that built-in software, NOT Windows tools. In fact, some RAID1 management tools would allow you to convert a single stand-along HDD to a RAID1 array by adding a matching HDD unit and then having the system copy all the data to the second drive. This is almost the same as the process to repair a damaged RAID1 array by replacing one faulty drive with a new one and rebuilding the array.
HOWEVER, Windows ALWAYS needs a RAID driver installed in it to use any RAID array. If you are simply booting from a "normal" stand-alone disk into Windows and then using a RAID array as a data storage system, the RAID driver installation can be done any time after Windows is running as you set up the new storage system. BUT Windows in ANY version cannot BOOT from a RAID array unless the RAID driver has been installed at the very beginning of the OS installation. This implies that, if you want to convert your single disk into a RAID1 2-disk array and use ONLY that as the HDD resource in the machine, you will need to re-install Windows, this time including the required RAID driver install at the beginning, in order to boot from that array.
I have read that there may be ways to convert a non-bootable RAID array into bootable by some complicated editing of Windows registry and boot files in order to force it to load the right driver at the right time from the right spot on a HDD, etc. But I am not SURE that would work. It's definitely for the adventurous knowledgeable techie.
So here's a quick guide to installing hardware RAID on a motherboard that features a RAID controller. These steps assume you are performing a clean Windows 7 install rather than an upgrade, and they might differ depending on your system set-up, but the general principles should be the same.
  1. Download the RAID drivers for your motherboard from the manufacturer's website and save them to a memory stick.
  2. Back up all your important data!
  3. Turn your PC off and unplug it.
  4. Install 2 hard disks preferably with identically capacity into your PC.
  5. Turn on your PC, press the delete key or F2 key when prompted to get to the BIOS menu.
  6. Find the option to select the RAID mode, save your settings and exit BIOS.image.axd?picture=bios-raid-options.jpg
  7. On reboot you should see a new menu option to enter the RAID controller settings. Enter the key combination when prompted to get to the RAID controller menu. image.axd?picture=amd-raid-menu.jpg
  8. Create a new RAID array selecting either RAID 0, or RAID 1.
  9. Select the disks that will form the array, save the settings and exit.
  10. On reboot press the delete key or F2 key when prompted to get to the BIOS menu.
  11. Check the boot sequence of your PC and ensure your optical drive is top of the list.image.axd?picture=bios-boot-sequence-options.jpg
  12. Insert your Windows 7 disk into the optical drive and exit the BIOS.
  13. On reboot press any key when prompted to boot from the optical drive.
  14. Windows 7 should start installing.
  15. Select your localisation settings and click next.image.axd?picture=localisation.jpg
  16. Click "repair your computer" and click the "load drivers" button.image.axd?picture=windows%207%20repair%20menu.png image.axd?picture=load-drivers-option.jpg
  17. Insert your memory stick and browse to the correct driver and install.
  18. Exit back to the Windows 7 install menu click "Install now" and on the next screen click "Custom (advanced)" to perform a clean install.image.axd?picture=install-windows-custom_thumb.jpg
  19. When you are asked where you want to install Windows 7 you should see that the 2 RAID hard disks are now visible as just 1 drive.
  20. Add a partition to the new drive so Windows with be able to recognise it.
  21. Continue installing Windows as normal.
Dec 04, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
Shut down with ''ckdsk scan to run on next reboot''. Now it runs the black screen and the windows screen pops up and shuts down right away. It goes back to the black start up screnn and repeats forever.
Your HD's probably bought it, but you can always try to read from it later after you reinstall to a new hard drive or drive array (striped SATA is fast!)
Aug 06, 2009 | Computers & Internet
Windows 2000 Professional will not format SuperTrak SX6000 array.
Update the BIOS of the card and the firmware... It might be bug!!!
Feb 23, 2009 | Promise Supertrak SX6000 (p29sts600000000)...
I installed a new power supply when i push the power button yhe monitor comes on for 5 seconds and then goes black
So could you please tell me what exactly was wrong with your previous power supply. I know it wud sound bad to you but sometimes faulty power supply causes permanent damage in your other hardware. So may be try to remove one hardware at a time and try to restart your PC without that hardware. If you would have same problem then install that hardware and try it with another one.
When you start your computer just start with basic hardware i mean only with keyboard, mouse , monitor and power supply.
But before anything please make sure your new power supply is giving right voltage and you have applied all connection. Some motheboard have special 4pin port for your CPU fan and for those motheboard you need a power supply with four pin wire only for ur CPU fan. Make sure your CPU fan is running. If not then you need that power supply
see these images
http://images.google.com/imgres?imgurl=http://www.playtool.com/pages/psuconnectors/12v4pinadapter.jpg&imgrefurl=http://www.playtool.com/pages/psuconnectors/connectors.html&h=365&w=355&sz=22&hl=en&start=1&um=1&usg=__smTu4Xc7VDpTb8XZI8Sm_Yv8AfA=&tbnid=p8hrXAAr7Uog9M:&tbnh=121&tbnw=118&prev=/images%3Fq%3Dpower%2Bsupply%2Bwith%2Bfour%2Bpins%26um%3D1%26hl%3Den%26rlz%3D1T4GFRC_en___CA204%26sa%3DN
If you are not sure please call any computer technician or take your power supply to him to check output voltage.
Good luck and hope it helps !!
Oct 01, 2008 | HP Computers & Internet
Epox motheboard
http://drivers.softpedia.com/get/BIOS/Epox/EPOX-EP4PLMI-Bios-119.shtml
I am not sure what version of the Bios you are currently running but the drivers at this site are V 1.19 and seem to be the latest drivers put out for your motherboard. The bios are good for all Win
Apr 29, 2008 | Computers & Internet
PC Chips PCChips A13G+ v3.0 Motherboard - NVIDIA GeForce 6100, Socket AM2, MicroATX, Audio, Video, PCI Expres Logo
69 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
