Question about Dewalt Vacuums
Need wiring diagram for Dewalt DC-500 Vac. - Dewalt Vacuums
Dewalt Service Center faxed me one!
Posted on Jul 31, 2008
Where can I download a wiring diagram for a Kirby Heritage vac?
just type "wiring diagram for a Kirby Heritage vac" in search engine
Oct 07, 2015 | Kirby Vacuums
My corded sawzall stopped working
Check the switch, internal wiring, and the power cable.
Feb 19, 2011 | Dewalt Cordless/Corded Wet/Dry Vac 2...
Dewalt 2gallon corded/cordless vacume...unsed one time brand new wont turn on. motor and switch both tested and work...any ideas
Check the battery contacts... a common problem on this model. they are easily bent and prone to corrosion.
Mar 08, 2010 | Dewalt Cordless/Corded Wet/Dry Vac 2...
Dewalt DEWALT Cordless/Corded Wet/Dry Vac 2 Gallon Vacuum: It was purchased new, and used only one time,the second time the unit was turned on it never worked and have never worked since, the motor and...
This vacuum has a history of problems with the battery contacts. Check that yours are not bent out of shape or corroded. if they are... straighten them or remove the corrosion.
Feb 18, 2010 | Dewalt Cordless/Corded Wet/Dry Vac 2...
Dewalt dc500 won't **** in water
there is a float ball or reed that closes off the exhaust port inside the canister, to prevent water from filling too high when used as awet vac. If lodged or trapped it will prevent suction or discharge in wet and dry modes. look at the housing that the filter attaches to and you will see it. if it doesnt rattle when you shake the unit up and down, it is stuck; otherwise, you must not be spinning the fan blades.
Jun 23, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Hayden 6000+ wont run
Define hose works or doesn't, no suction, hose will not activate vac , etc.
Test the vac by shorting across the low voltage terminals where they enter the machine. If the vac works here your problem is in the internal wiring, at the valve or the hose to wall connection. If the vac will not run, you will need to check the motor for continuity across the motor leads.
Apr 18, 2009 | Hayden Industries SuperVac 6000 Central...
DEWALT DW795 Vac filters
IT looks like the part number is 429704-56 and the Dewalt site shows list price being $51.68. You should be able to order that filter at a DeWalt dealer in your area, hopefully for a discount.
Otherwise, there is here online:
http://www.ereplacementparts.com/search_result.php?osCsid=2c10ce07c62a161bca9f80f981bf690f
Jan 29, 2009 | Dewalt DW795 Wet/Dry Vacuum
Oreck Orbiter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618779&thid=681757
Oreck Orbiter
Posted by eccott on Jun 18, 2008
Hi could you e-mail me a wiring diagram for the Oreck Orbiter please? I need to replace the mains cable & the cable to the motor. Thank you, Helen Eccott.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Orbiter Floor Machines ORB-500… you can contact the customer service line / tech support @ the Oreck Factory that I will list below for you and they will be happy to help or assist you in the wiring diagram, please include the model # and serial # with your request. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Oreck Orbiter Floor Machines ORB-500,...
DeWalt DC500 Shop vac
the problem on your vacuum is the dc - dc converter.u cna replace them but to follow the same connection.
Oct 02, 2007 | Dewalt DC500 Canister Wet/Dry Vacuum
Vacuums Logo
349 people viewed this question
Top Dewalt Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pcm2048
Are you a Dewalt Vacuum Expert? Answer questions, earn points and help others
