Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Unit touchpannel not working after water filter and ventilate
My Saeco Incanto is not working after I changed water filter and did the ventilate function. The touch screen in not working. The steam valve works but I can't make any coffee!!
  • Anonymous Dec 24, 2008
    I have an S-class incanto sirius.
    I left the steamer on too long and now have a bit of water in the display unit. How can i wipe this down
  • 515 Answers
Make sure you not get any water inside the touch screen.
Posted on Jul 30, 2008
I have saeco incanto coffe machine and when I have turned on the machine message appears Ventilate.
hi,probably your machine is need decalcify. Try to turn on the hot water knob when you start the machine. Fill about 1 water glas with hot water from machine.If the ventilate is still appear-you must decalcifying machine with special liquid for descaling.
Jan 04, 2015 | Saeco INCANTO DELUXE Espresso Machine
Hot water ventilate problem for Saeco INCANTO DELUXE Espresso Machine 2 signs at a time "hot water" +"ventilate" "
Place a jug under the milk frother and turn the steam knob to allow hot water to flow.
Ventilate will clear after a short time
Jan 27, 2013 | Saeco INCANTO DELUXE Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Jul 28, 2009 | Saeco Royal Professional Espresso Machine
My saeco s-class incanto sirius machine keeps say replace water filter & ventilate even after I replaced filter
Sounds to me that water is not getting to the pump. Try charging the water filter before using by letting it sit in some water for about 5 mins.
Jul 23, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Sirius S Class
Take off the top of the machine, look at the printed circuit card and see if you can see anything that is broken.
Look at the fuse in the machine to see if they need to be reset.
Best regards
/Mirran
Oct 17, 2008 | Saeco Incanto Classic Espresso Machine
Saeco incanto sirius
It can be the touch board or the "water turbine" in the machine
May 25, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
289 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
