Question about Intertherm Heating & Cooling
I have an Intertherm waterheater in my park model trailer. It is less than a year old, and leaks around the drain valve. (I think) How do I get the valve off, is it just threaded on?
  • 1,420 Answers
Yes and most likely it is a cheap plastic valve. You will need to turn off the water to the heater and drain it completely. Pick up a new Brass valve at your local Lowes or Home Depot and wrap 5 windings of Teflon Tape on the threads of the new valve. When wrapping the tape on, hold the valve so the threads are up and start wrapping the tape Clockwise. If you do it the wrong direction the tape will peel off when threading it in the heater.
Posted on Jul 31, 2008
Leaking drain valve
1) Copy following link:
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html#repair
2) You may find it is easier to put garden hose cap over dripping drain valve.
Screw very tight with channel locks.
3) Add comment and say what you discover
Feb 08, 2013 | Water Heaters
Atwood g6a-be lights but goes out in 3-4 min.
mine is pretty new about a 1year in halve to two years old. i light with lighter it lights burns great then acts like propane cutts out then burns low then cuts out kinda acts like propane pressure cuts out in the valve but i can relight 30seconds later same thing. i have checked stove it burns great. is it in the waterheater propane valve. need help pease i need a cheap fix layed off right now. thank you dave
Sep 20, 2012 | RTO Atwood Water Heater - 6 Gal LP
On demand hot water heater leaking
is this an area w/a threaded fitting?if so ,you turn off waterheater,drain,disconnect existing fitting,clean and rewrap with new teflon tape ,and retighten down.i only say to drain,because i am not sure if it is hanging and would not want to fall on you.teflon tape and rewrenching down should fix,unless soldered.then call your plumber.also if under warr.from installer ,less than 1 yr.,call them and tell them to fix it for free.i have over 13yrs in sheetmetal install,both in hvy.industrial down to many other types of home install of furnaces,a/c units,retrofits in /new and existing homes,waterheaters,garbage disp,refrig.water lines,gas etc
May 21, 2012 | Bosch Water Heaters
I have a Park Model RV with a Rheemglas Fury model 81VP205 with no bottom drain. How do I drain the water heater to winterize for the cold Northern Winters?
Make sure it's off (hydro) and open drain at cold line going in bottom wherever you find a drain (usually close to it) going down through floor and outside under trailer. Follow cold line back until you see a line "T" and one line going down under trailer, and open it up underneath. Then open pressure relief valve at top of tank to allow for faster draining .
Oct 14, 2011 | Water Heaters
Hot water leaking from what i think to be the pop off valve. i tried to tighten it a little and it started leaking more. The unit is 16 years old. The excess water is draining into the catch pan and then...
Hello
16 yrs old? Im guesing this is a hot water heater.Not a air conditioner.
If its still making hot water you may not need to replace the whole unit.
The valve that is leaking is a high pressur relief valve and they do go bad the sprigs become weak over time and some corrosion may not allow the valve to seat properly.
1st step is to shut off all incoming and out going water to the tank.
2nd Shut off fuel or gas to the unit, and annonce to everyone your are working on the hot water heater.
3rd at the very bottom should be a drain valve much like a hose spicket,open this slowly and drain the tank,remember the water will be hot.You may not need to drain it all the way,while draining pop open the relief valve,when you stop getting water from it,you are below it and can turn the drain valve off.
4th remove old relief valve and replace with a new one,i think they are rated at 15 psi or 30 psi blowoff pressure,hopefully there is a tag on it with that info.
When you go to install your new one use some pipe thread compound or teflon tape around the threads before you reinstall valve.
Once done slowly refill tank with water, check for leaks.When full open up hot water valve to house and relight buner.open a faucet in kitchen to hot to bleed off any air.
Jan 14, 2011 | Heating & Cooling
My water heater is leaking cold water from the bottom. How do I fix it? its a Richmond miser. Model # 8v30-1
First shut off power then remove acess cover and carefully move insulation out of the way so you can see around elements.Check to see if leak is coming from around element.If it is determine what type of element you have. Either screw in or bolted in. Both have thick rubber gaskets that can be replaced by draing water heater and removing element then install new gasket and reinstall element.
To drain heater shut off valve on incoming cold water supply line ,make sure electric power is off. Connect drain hose to drain valve and put other end to floor drain or sump basin.You can open faucet on hot side near by to prevent vacumn and drain. If you have screw in type disconnect wires,marking them for reattachment,then use large open end wrench or pipe wrench on hex section of element and turn to left to remove. If you have bolt in element spray bolts with wd-40 or similar and carefully loosen bolts then disconnect wires and remove element.install new gasket and reverse to reinstall. I would recommend that you replace elements at this time if you are sure this was the source of the leak.
If you don't think it's leaking around elements then check fitting on both water lines to water heater to be sure they are not leaking and seeping down thru insulation and leaking out of the bottom of heater. Next check around drain valve for leak and if it's leaking you can try tightening it a little or replace it with 3/4 x2 brass nipple and 3/4 inch female iron pipe boiler drain. Use teflon tape or pipe joint compound on all threaded connections.
After you have eliminated all other sources for leak then it is probably the tank itself. If it is less then six years old the tank should still be covered under warrenty. Most warrenties will give you a new heater but installation will not be covered unless you have extended service coverage.
I hope this helps you some. Thank you
Dec 27, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
I own my trailer but is on a rental lot-i have water coming up around toliet and sewage up into the tub. We just recently had the main line under trailer jet sprayed. What do i need to do? if i replace the...
If the toilet to the floor flange wax seal is leaking that is your problem, it's your trailer. Most likely it would have leaked, but since there was no blockage, it just kept going down. Now you have blockage either in your system, or in the park's sewer system. You said you had your main drain jet sprayed, did that help or for awhile? Depending on how many bathrooms you have, usually in a trailer the main drain is near the main bathroom. If you have sewage backing up in your tub, then the whole line is backing up. If you have a long run under the trailer before it goes into the ground, make sure it is open and enough fall. If it's in the ground, then it's the park's problem. Have the park clean the line from where you connect. Any neighbors ahveing problems? Does your sewer line go to a septic tank or a treatment system.
Jun 27, 2010 | Home
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
I have water leaking from the bottom of my waterheater PE50T9A
It is possible that the water heater has a leak at the bottom. They eventually rust out. The valve should be removed if it is leaking and you should replace it. They are cheap. Be sure to use teflon tape to seal it back up
Apr 27, 2009 | Water Heaters
Restricted air inlet
Clear the area around the bottom of waterheater so as to allow air flow around mesh area built into base of water heater and or open unvented door passages involving waterheater. This mostly a safty issue which seldom occurs if not remedy quickly.
Please rate. Thanks JJ505
Mar 29, 2009 | General Electric GE SmartWater Household...
Heating & Cooling Logo
251 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
